JDM Black Window Trim
Hey,
I searched on this but wasn't able to find a definative answer:
To install the JDM black window trim, do I need to remove the interior door panels?
Thanks!
-Jeff
Thanks!
-Jeff
In that post, it looks like nader-tsx only replaced the top trim pieces, not the bottom/flat ones...
To replace those, do you need to take off the interior door panels?
無限 本田 CL9
if you are referring to replacing the stock outer door trims with black jdm ones, then no, you do not need to remove the door panels
I reall that tsx fury did this mod, and in his post (do a search) he says he basically just peeled/ripped out the oem chrome trims which are held on by glue/tape
Yah, definately, but I just don't want to do it if I don't have to. I can never take out too many interior parts before I start scratching things up ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Thanks for your help!
Looking at the parts diagram, it appears that the bottom trim pieces each have 1 screw...I'll have to check to see if I can access that without taking off the door panel.
Bye TSX, hello domestic?
TLDude876
12-28-2016 03:18 PM
Iakonafuji
09-21-2015 02:39 PM
nuldabz
09-03-2015 05:49 PM
