Jackson Racing Supercharger
Naturally ASpirated!
Im wasnt sure if this is true or not, but I read some thread a while back and I recall someone running the Jackson Racing Supercharger for the DC5 kit on their car... I tried to search but couldnt find you... Just wondering if you can answer some questions I had...
their website has a basic K series kit. If you run that with a duel ecu from HONDATA, it could work. Of course you might need to do some mods to make it fit because it's not TSX specific. I haven't heard much more about a full kit yet though.
Unregistered User
U will need an adapter bracket to fot the supercharger itself properly and K-pro to tune it. they had the issue of air/boost leaking when tried it without any mods.
Thanks all for the response but I recall the guy having the DC5 kit cuz JR has two different sets of chargers, the street and race...
basically anything is possible now because of K-Pro. However, the only real FI option that comes complete right now for the TSX would be Comptech.
and samxeyeam... 유리 in english is Yuri!! and it's Gee gee gee gee, not 지지지지 hahaha.
지지 = dirty, but I'm guessing you knew and that it was just a play on words. regardless. 지금은 소녀시대!!! huge fan, too!
I dont want to go with comptechs because they are overpriced and i think the design of the JR's might be able to push out more power... Oh well I guess its going to be a learning experience...
where is my garage?!
1 Post
good move. haha.
man, when i was buying my TSX, it was down to a super low-mileage 06 with some extra junk (spoiler, tints, lo/jack, etc...) or a brand new 07, both AT's and non-navi. the 06 had some weirdo paint damage and looked like it had sat out in the lot for a year (which i guess it did), and they were asking more that than the 07. so i bought the 07.
if i knew what i know now, the 06 would've won. even if the payments were higher. but i always wondered why that car was sent back with so little miles on it.
I am willing to take risks... I dont see it having too many fitment problems because a K20 and the K24 dimension wise isnt that big of a difference... Plus the TSX engine bay does have abit more room to play with...
Theres two kits for the RSX... Do I get the 02-04 one that comes with the 3.8" pulley or the 05-06 one with the 4"?? Not even sure its only the pulley difference also because they are 200 bucks in difference...
This is ridiculous.
JRSC $3500
kpro $2000
Fittiment other crap $1000
$6500 vs $3800 for CTSC
Are you just trying to be different or do you want a reliable and faster car. I say get the CT SC and be done with it.
JRSC $3500
kpro $2000
I think the numbers goes like this....
CT charged Reflash TSX: 220-230whp
HyTech'd K-Pro TSX: 230-235whp
HyTech'd K-Pro CT charged TSX: 335??? Its on here somewhere... Or its on Tclub.com for sure..
JRSC 2700
KPRO 1400 (supplying your own stock ECU)
Can change boost levels using K-Pro.
CT charger 4400
Stuck at 5psi's...
few things... 1) When did HyTech come into play? 2) If you have K-pro you can most likely change the boost with the CT product as well. 3) WHP is one thing. The numbers are great to boast about but someone who has done some good modding of the car basically said anything over 300 is alot for this front wheel drive application. I prefer the car to be ultra driveable vs. having the highest dyno numbers around.
2) If you see the prices, if you get K-Pro PLUS CT thats running you over 6k instead of 4100.
3) With that setup, its still going to be driveable...
Thanks for your input anyways.
Unregistered User
I do think that alot of this stuff is moot because I don't believe anyone would do all of this supercharging or whatever without doing many if not all of the basic bolt on's first. At that point your can be at a few grand anyway depending on the companies you use. The mod itch is usually scratched progressively; not all at once. Good luck with you choice.
A reflashed CT charged TSX is not that great... A HyTech'd TSX with K-Pro puts our more HP than a reflashed CT.
Sorry, but both of these posts are incorrect.
1) A manual S/Ced TSX with full bolt-ons should be hitting ~245-250whp, whereas a manual N/A HyTech TSX w/ K-Pro is putting out about 225-230whp.
2) The 338whp was put out by Doug @ Hondata (the godfather of K-Pro). However, this is a relative number as the pulls were done on Church's Dynapack dyno which typically reads 10% higher than a standard Dynojet. That means comparing apples to apples, a TSX with S/C + HyTech is hitting ~310whp on a Dynojet (I know because that's where I'm at as well).
3) TSX K-Pro is $1,395 only if you supply a 2nd ECU (from either RSX or Civic) beyond your stock ECU because the TSX design requires two separate ECUs to function: one for engine management, and one for everything else (gauges, HVAC, etc). That means you have to buy an additional ECU, and they run anywhere from $300-500. So net cost to get K-Pro will still be $1,700-1,900.
4) I don't believe K-Pro can directly adjust boost levels on its own. However, it does have an input which you can use to connect a boost controller.
5) On a S/C application, boost control is irrelevant anyway. The only way to adjust boost is to swap to a different sized blower pulley.
6) With the CT S/C kit, they provide you with all the tools you need to adjust the fuel system in order to increase flow using the stock injectors for 5psi of boost. If you plan to go above that with the JR kit, you'll need to get larger fuel injectors (~$500) and a tune ($700-1,000 depending on where you go), so you also need to factor that into the cost over the CT kit.
One thing that is nice about the JR kit (for now, anyways) is that there are some RSX guys that have managed to squeeze a tiny aftercooler into the JR manifold which apparently works well. That is my one beef with running higher boost levels - the lack of a true cooling method. I am currently running water/methanol as a chemical intercooler (and octane booster), but I'd much rather run an air-to-air setup if there was one available.
C'mon, Mr. Senfield...where's that new intake manifold???
He has the DC5 JR supercharger on his TSX.
Hytech exhaust system $2500
kpro $2000
Tune $500
$5000 DAMN!!! vs $3897
Get a dc header and exhaust for cheap and your maybe 4500. Crap its expensive to mod this car.
1 Post
do you lose any features with those kits?
the newer jackson racing site which links to the kraftwerks kits says the k-series S/C requires removal of the a/c compressor. does that mean you lose a/c? or does another component take care of it?
...Acutally BoostByGear works for superchargers too now, although it can only be reduced somwhat not increased above whatever size max psi the pulley you have on the charger will produce...My buddy has been testing it and it works well.
Trolling EliteCM.net
I'll assume when you're trying to use a JRSC for a Type S. If you're looking to bolt on a K20A2 SC on to a K24A2, it's possible. You will need a Hasport Intake Adapter because the K20A2 head does not have a coolant port like the K24A2 head does. The adapter basically adds the coolant line that is normally found on the TSX's injector base. Your next big hurdle is how to get your throttle body to fit on the RSX Type S inlet on the SC. I don't believe anyone makes a TB adapter, but I could be wrong. Maybe Karcepts would be able to machine an adapter since they offer a reverse adapter (RSX Type S TB on a TSX IM). The RSX Type S TB is cable driven, so that is out of the question. Other than that, you will need to replace/extend some coolant and vacuum lines and extend a few wires on your engine harness. Depending on whether there is a clearance issue with the inlet of the PS pump and the snout of the SC, you may need to tap the other hole on your PS pump so you can flip the inlet up to allow the PS inlet hose to be routed over the belt. I've done this on a K24A4 with a Comptech RSX Type S SC, and since the motors are fairly similar, I figured I could provide a little bit of advice.
My only concern with this would be the TB. I would recommend using KPro since Hondata makes a dual ECU harness for your cars and offer an ECU reflash. I only wish they offered that for my application instead of having to use a custom harness.
lanechanger
10-13-2015 10:56 AM
Joe Avesyan
09-29-2015 03:57 PM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
