Intake/throttle body upgrade.
Old Dec 27, 2020 | 07:24 PM
Jonny Montiel's Avatar
4th Gear
So I’m getting idle issues with my 06 tsx and I’ve figured it has to be the throttle body. I’ve been looking at some intake manifolds and throttle bodies online. My question is would the car function normally if I was to upgrade to a bigger tb and maybe an aftermarket intake or would it need to be tuned or reflashed for it to run normal? It’s a DBW tb if that info helps.
Old Dec 27, 2020 | 07:27 PM
it would run and it would run properly, however, to get the most potential out of it...you would need to optimize the ecu by tuning the ecu for the extra air.
but yeah, you can run a larger throttle body with no ill effects, may even gain a few ponies....it's only when you want to take FULL advantage of the larger throttle body is when you would want to tune
DriverOne
3G RDX (2019+)
69
Jan 2, 2021 09:37 PM
kingkong_dav
May 17, 2014 11:07 AM
07HONDATL
Jan 31, 2014 11:55 AM
alleyesonmeee
Sep 21, 2004 09:09 PM
