intake manifold gaskets
i just confused the hell out of myself
as far as i know there are 3 different types of img for 2004-05 tsx:
comptech
hondata
p2r
now, i already have the comptech unit and just ordered the p2r -- will they work in conjunction with eachother? i know that hondata and p2r will work together ... i'm running under the assumption that the ct/hondata img are essentially the same thing?
please help,
vinny
as far as i know there are 3 different types of img for 2004-05 tsx:comptech
hondata
p2r
please help,
vinny
Check it out: https://acurazine.com/forums/showpos...6&postcount=13
Hondata gaskets is #11 and P2R thermal intake gasket is #3. Hondata gaskets is in Injector base and P2R is in intake manifold. Check link for P2R gasket with model #103, but 113 is same type of Hondata gasket. But Comptech is same as Hondata, but I believe Hondata is probably better. I already order P2R gaskets already and expecting to get it by Saturday.
not sure where the comptech one fits, but i know you can use the p2r and hondata gaskets at once. they're just placed in different parts of the intake manifold.
i actually have both sitting in my apt. i just need to find a time to install them.
Originally Posted by godfather2
are you positive that the comptech gasket and hondata are interchangeable. please chime in everybody ...
Yes Hondata and Comptech gaskets serve the purpose. So it comes down to you choice which you want to go with
thanks bro. just to clarify: i already have the ct gasket installed. now i ordered the p2r and it looks as if they can work together to cool things down a bit. THANKS FELLAS
CL9 ABP
Its the same godfather i just did a search yesterday and found out i had both hondata and comptect gaskets sitting around.
i'm missing the p2r gasket.
oh how was the install?
if the hondata and p2r gaskets mount in diff locations, how does that diy help?
kinda weird that p2r doesn't include instructions, but i guess they just people can figure it out.
edit-refer to gsgomez's post. he described it correctly.
and will not appear on this weblog
Good,and tell us funny thing!
Remember these are averages, and the
has been in a drought for some time. Old timers in
Prescott will tell you how almost every afternoon in July and August they got their almost like clockwork.
They still get quite frequent short showers but for the last few years they have not been as regular
etching machine-etching machine help you to power
shanghai massage-massage vip service in shanghai
metal etching-metal etching help you to power
photo engraving-photo engraving help you to power
Originally Posted by losothefatso
Can anyone explain it to someone who never installed the Comptech or Hondata gasket how to install the P2R Intake Manifold? :p
How much detail would you like?
For instance, you have to remove the IM cover (says iVTEC on it), you have to remove a bolt/bracket that supports the IM from underneath, you have to remove the TB intake tube, etc etc. To you need torque specs too? Since this is an aluminum piece, you do not want to over tighten.
Argh, intake manifold gaskets seem too long to install I just went with the spacers + gaskets :[
hmm I heard take off the studs is a pain in the ass.
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
