Installed Comptech header, RT cat, and Evo2
Three hours on a lift and everything is in. I was very impressed with the fit and finish of all three pieces. Only gripe is that the cat should be o-ringed or at least come with the needed gasket. After four hours of driving, I got the CEL. I'll install the defouler next chance I get. The sound is great, and much lower than I expected.
I got the CEL. I'll install the defouler next chance I get ???????
^im confused with the above
i have the evo 2 installed as well and absolutly love it, the rt cat and competech header are on there way also!!
what do the gains look like?? are they noticable?
Prepare to get a defouler as most ppl w/ HFC has CEL.
Former Sponsor
The TSX ECU has very strict parameters for exhaust flow so when it sees more flow than it likes it throws a CEL for Catalyst Efficiency Below Threshold P0420. You can just add a defouler (basically an extension for the 02 sensor to push it further away from the exhaust stream) and it will eliminate the CEL. I have them for $20 shipped for straight defoulers or $30 for the angled one or you can make your own for like $8-$10.
If you buy them, you need to drill them out slightly with a 1/2" drill bit otherwise the O2 sensor will bottom out. I'm still trying to find my set that I bought b/c I'm clearing my codes now 2-3x per week. I think it has to do with the winter mix gas here. Didn't happen at all in the summer.
The Evo 2 is really loud when new. After a week or so, the exhaust will sound a lot better. At idle, you probably wouldn't hear it outside the car unless put your ear closer to the exhaust.
Question: Will I get a CEL for having an Evo 2 and a header or does the cat usually cause that problem?
I don't know for others, but for mine, it's funny. The CEL only pop up when I drove @ a steady speed + low rpm range (under 3K); an e.g would be driving 100-120km/h on hwy. When I drove aggressively, step in/lift of the gas ofteh, it won't pop up.
By any chance you happened to know the cells # difference between 04-05 & 06-08?
94 DC4 RS LSV/Turbo
I also has an angled defouler, it was made by a guy from CRSX forum. Everyone claimed their CEL has been eliminated (on RSX); when I installed mine, it does DELAY the CEL, but it comes back in like 2-3 weeks.
ive had a couple cars like that. with the varying rpm around town it can't take as accurate a sampling as it can in steady driving.
Sounds sweet!! I have the same set-up. I don't even remember if I have a defouler on my RT CAT, and it works fine. I didn't want to bother w/ the trouble hence why I didn't do the straight pipe!!
BoricuaTL
Apr 8, 2016 01:08 PM
k6biv
Sep 10, 2015 06:37 PM
and high flow cats is about 200-300 cells depends on brand. this makes me a 2nd thought about getting a high flow cat.
