Injen Replacement Filter
Old Oct 26, 2005 | 07:17 PM
fatcat's Avatar
Hi, I want to buy replacement filters for my RD1430 CAI. Does anyone know what the K&N part number is? I know that Injen sells one for like $50 (X-1014).
Big reason why I don't want to spend time cleaning it is that I am busy at work and need to drive over the weekends. I'll install the new filter and clean my old one, and when the new one gets dirty I'll just reinstall the old one.
Please help.
Thanks.
Old Oct 26, 2005 | 07:30 PM
curls's Avatar
Someone stole "My Garage"
Doesn't it only take about 10-15 minutes to clean the filter once its out? Probably just as quick as replacing it with a new one!
Old Oct 26, 2005 | 07:35 PM
fatcat's Avatar
After you clean it don't you need to dry naturally overnight?
Old Oct 26, 2005 | 08:10 PM
RMATIC09's Avatar
I wish cleaning it wasent such a pain, do i physically have to remove the intake to clean it ....its been 19k miles since i got it
Old Oct 26, 2005 | 08:17 PM
Tsx536's Avatar
Rep'n Taxbrain.com
No, you can remove the filter by going in through the wheel well. I was able to take mine off without even jacking the car up and removing the wheel.
I just turned my wheel all the way to the right and went at it.
Old Oct 26, 2005 | 08:28 PM
jmathew34's Avatar
to clean the filter, you have to remove it, spray it with the cleaner, let it sit for a few minutes then spray it down, then let it air dry (10-20mins) then spray on the oil and let it set for about 15-20mins and then reinstall.
that's the procedure to clean a k&n filter....
Old Oct 27, 2005 | 10:01 AM
gfd1182's Avatar
i have a AEM SRI i want to replace the filter what brand should i go with?
Old Oct 27, 2005 | 12:41 PM
RMATIC09's Avatar
thanks kenny, so i dont evne have to remove the wheel or the intake? Your saving me alot of trouble these days
Old Nov 1, 2005 | 12:57 PM
RMATIC09's Avatar
bump on not having to remove the wheel or intake to clean it...any picture instructions for this
Old Nov 1, 2005 | 01:56 PM
joerockt's Avatar
Just dial 1911
The Injen? No you dont. I just did mine recently and all you need to do is partially remove the fender well cover, and bam, theres the filter.
Old Nov 1, 2005 | 01:59 PM
joerockt's Avatar
Just dial 1911
Did you install it yourself? There are a few clips that you need to remove along the fender well (front side of the well). There are a few clips just underneath that need to be removed as well as a couple of bolts. Its pretty easy once you look at it.
Old Nov 1, 2005 | 07:48 PM
RMATIC09's Avatar
Thanks guys
how did u clean it rocket?
Old Nov 1, 2005 | 09:50 PM
TSX2345's Avatar
A DiRTBAG decal on my
id like to know too
Old Nov 1, 2005 | 10:39 PM
xjessejun's Avatar
when do you clean injen cais? every 45k miles?
Old Nov 1, 2005 | 10:43 PM
RMATIC09's Avatar
it says 10.....
Old Nov 2, 2005 | 08:15 AM
fatcat's Avatar
This is what I did:
I bought the K&N recharger (cleaning kit) at the local pep boys. Went home, took out the filter through the fender, pulled out the lower portion of the CAI (wanted to switch to short ram), got a bucket, placed the filter in the bucket, sprayed the filter with the K&N cleaning solution, went through half the bottle, let it soak for 10 minutes, spray the filter with hose, let the red dye run off, fill bucket with water, left the filter submerge for 30 minutes, hosed it down again, then took it into the house to dry. After the filter is dry, you need to apply the K&N oil throughout the filter. Just make sure the color of the filter is evenly red. Let it stand for 30 minutes, then plug it back into the intake.
Old Nov 2, 2005 | 09:32 AM
RMATIC09's Avatar
thanks fatcat
did you notice an increase in power after cleaning it? my thing has been on for 20k miles almost...
Old Nov 2, 2005 | 10:38 AM
joerockt's Avatar
Just dial 1911
Originally Posted by fatcat
This is what I did:
Make sure you rinse the filter from the inside out, otherwise your just pushing dirt deeper into the filter if you blast it from the outside.
And theres no reason to use half the bottle of cleaner. Just spray till its saturated and let it sit.
Old Nov 2, 2005 | 11:42 AM
xizor's Avatar
Bye TSX, hello domestic?
thanks fatcat
Did mine last week, butt dyno didn't feel a thing
Old Nov 2, 2005 | 12:30 PM
RMATIC09's Avatar
oh well.....wonder what mine looks like
nanos
Nov 12, 2015 08:41 PM
ibGTV
Sep 28, 2015 03:40 AM
Skirmich
Sep 15, 2015 06:41 PM
datadr
Sep 12, 2015 09:12 PM
Aleax
Sep 9, 2015 08:04 PM
