idling with intake
Old Mar 10, 2005 | 01:40 AM
CgTsX808's Avatar
New CG tsx owner
idling with intake
i was just wondering who rpm people are idling at with an intake. i have an injen, and before i put it in, i was idling at 1000-1200 with the car warm. now i am idling at around 800-950. just trying to compare it to others with injen cai, wondering if it is normal.
Old Mar 10, 2005 | 01:53 AM
CL9projektz's Avatar
idled at about 750-800 b4 and after intake.
Old Mar 10, 2005 | 01:55 AM
TSX 3Pedal's Avatar
Use all 3 Pedals at once
^^same
Old Mar 10, 2005 | 01:56 AM
JTso's Avatar
The idle rpm shouldn't change, unless there's a vacuum leak somewhere...
Old Mar 10, 2005 | 02:11 AM
PixelHarmony's Avatar
Master Graphic Artist
yeah, my idling hasn't changed either. JTso, for some reason on the intake install for myself the vacuum line is a little pinched (there should still be airflow), should this be a problem?
Old Mar 10, 2005 | 08:24 AM
xizor's Avatar
Bye TSX, hello domestic?
i helped install someone else's intake and right after installing it idled at 1200 and then went down to 800 after 5 minutes.
Old Mar 10, 2005 | 10:01 AM
JTso's Avatar
If you are talking about the hose that connects from the intake to the valve cover, then you are fine. That hose isn't really a vacuum line, just air hose. You might be able to take the kink out by shorten it by a few mm, or rotating it around. The vacuum leak that I was referring to is any lines that connect to the intake manifold or sensors that connect to a vacuum source. For example, the PCV valve connection is one of them.
Old Mar 10, 2005 | 11:07 AM
ClutchPerformer's Avatar
....i have an injen, and before i put it in, i was idling at 1000-1200 with the car warm....
This sounds suspect...
I'm not saying that you're lying, but that's just not where the car idles at. Are you sure the engine was warm?
Old Mar 10, 2005 | 12:09 PM
iamhomin's Avatar
04 remembrance
Something definitely doesn't sound right. I havent seen an automobile that idles above 1k when the engine's warm.
Old Mar 10, 2005 | 01:47 PM
Stokeless_TSX's Avatar
Stokeless
sounds like he has a proble with a sensor on the intake manifold. Making the ecu think the engine is too cold. Did you try the TB bypass by chance? And possibly screw it up?
Old Mar 10, 2005 | 02:27 PM
xizor's Avatar
if you screwed it up your radiator fluid would leak everywhere, you'd definately know if that happened. it has to be something else.
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
DerrickW
Nov 15, 2015 05:52 PM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
