How to remove trim piece above center box and below HVAC
Hi all,
I have a 2004 TSX. I'm wondering how to remove that small piece located between the center box and the hvac area. I've tried searching, but didn't seem to find anything...
Ok, I figured it out. At first I thought you just have to remove the hard to get to screws behind it. I ended up having to remove the whole radio unit to get to the screws and what do I find when i turn the unit around... It's one piece... you can't remove the little piece, unless you want to cut it off. Also attached behind that small protruding piece are two clips that help hold the bottom end of the radio unit in place. I believe you can do without them as there are two screws beside the HVAC area also that help hold the radio in place... Nonetheless, i don't think I will cut it to make more room for my project.
Oakes
Wash & Wax
10-12-2015 11:17 AM
ulrblitzer
09-24-2015 07:42 PM
