How did you cut your bumpstop
Bye TSX, hello domestic?
I'm bored, so asking more future modification questions. Neuspeed's springs don't have any instructions for cutting the bumpstop (or at all), so I'm wondering how much everyone did?
How much did you cut, inchs, %?
How's the ride?
Have you bottomed out?
How's the ride?
Spring designs have changed over the last few years. When I had my Eibach and Neuspeed a few years ago for another car, both instructed to trim the bump stops to the amount being lowered. Now, manufactures are designing the springs to use with the bump stops. They even go as far as calling the bump stops "internal springs". When I first installed the Neuspeed, I trimmed the bump stops and noticed the front drop was more than expected but the rear was not affected. I later contacted Neuspeed and was told it's not necessary to trim the bump stops. However, they recommend trimming only the very bottom section if necessary. HTH...
Subie Tech
How's the ride?
How's the ride?
Originally Posted by djtrancetastic
I didnt get neuspeeds, i got the Tanabe's and Pann Motorsports in Sun Diego does'nt recommend cuttin the bump stops.
I haven't cut the bump stops in the last two springs I put in. You usually only need to if you are dropping it over 2-3"... but when you cut your bump stops, you are also much more likely to blow the seal on your struts..
MrHeeltoe
20
02-23-2023 01:54 PM
mlody
12-04-2019 02:11 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
polish_pat
09-25-2015 12:24 PM
