How to crack open the headlights?
Old 11-03-2006 | 03:04 PM
S14 n Tsx's Avatar
mmmmmm....
I tried to search and came out with nothing.. any good DYI with pictures would be great
thanks,
Old 11-03-2006 | 03:30 PM
DuckyTSX's Avatar
Bake them in the oven... Then pull it apart
Old 11-03-2006 | 03:35 PM
S14 n Tsx's Avatar
mmmmmm....
well I know that but need more better detail than that...
Old 11-03-2006 | 04:25 PM
DuckyTSX's Avatar
http://www.members.tripod.com/megatr...es/Page338.htm
Old 11-03-2006 | 04:49 PM
S14 n Tsx's Avatar
mmmmmm....
that was it! thank you..
Old 11-03-2006 | 05:27 PM
JTso's Avatar
What are you working on?
Old 11-03-2006 | 05:49 PM
S14 n Tsx's Avatar
mmmmmm....
hehehehe! j...d...m headlights.
Old 11-03-2006 | 06:21 PM
gftgrill's Avatar
if you put your lights in the oven. keep the temperature around 200 - 250. plastic melts.
on my civic I would line the bottom of the oven with aluminum foil so I wouldn't have to clean anything up afterwards.
and above all else, take your time. if you need to put the light back into the oven 2 or 3 times, that's fine. it's better to spend alot of time than to fuck up a light.
Old 11-03-2006 | 06:24 PM
S14 n Tsx's Avatar
mmmmmm....
the person didn't mentioned about the glue part? do I need additional glue to seal them together?
Old 11-03-2006 | 06:26 PM
S14 n Tsx's Avatar
mmmmmm....
what kind of glue did you use? and what you mean by putting the light back into oven 2-3 times??
thanks,
Old 11-03-2006 | 06:30 PM
gftgrill's Avatar
in sakes of not having to reopen them to reseal them. I would do it just to be safe. I always used an RTV ? silicon sealant that can be had at auto zone for about 3-4 bucks.
I always went heavy on the silicon as to ensure as good of a seal as possible. I would rather clean up excess silicon off of the outside of the assembly than reopen it and reseal it. the silicon basically has a 1 time use. if it doesn't seal the first time then you have to open it up and scrape out all of the silicon from the first time.
for the silicon I recommend getting some disposable vinyl/rubber gloves. and wear old clothes that you don't care about. that silicon seems to have a way of getting into places that you'd never guess and it's a pain in the ass to scrape off.
Old 11-03-2006 | 06:34 PM
gftgrill's Avatar
thanks,
I used a clear silicon sealant. I more than likely you won't get the assembly apart on the first try. keeping the glue warm helps alot. so when you're trying to open it, it will start cooling, so you might need to put it back in the oven to keep the glue warm enough that you can pull it apart.
when opening the lights the first time, the most helpfull tools I had were a very tiny screw driver (1-2 mm thick. just slightly bigger than eye glass screw drivers) and a pair of wire cutters. you use the little screw driver to get between the two halves of the assembly and use the wire cutters to cut the glue.
Old 11-03-2006 | 06:44 PM
S14 n Tsx's Avatar
mmmmmm....
thanks for the info but how do you know that the headlight isn't seal all the way or not? I mean this is going to be my first try so its going to take some skill and time to do this. I rather leave it how it is but in my case, I'm gonna need to open it up and do some replacing so... btw, are those silcon sealants black? Is there choice of color to this? oem is black so I want to match it up.
thanks,
Old 11-03-2006 | 06:51 PM
gftgrill's Avatar
thanks,
if there is glue in the light assembly, then it will be all the way around. the only lights I've ever seen without glue were bmw's. if your goal is to only replace the projectors, then you should be able to remove them without opening the lights.
you never said what your actual goal is.
the silicon that I've always bought was clear. I guess you might be able to find it in black. but I've never gone looking for it.
Old 11-03-2006 | 07:04 PM
S14 n Tsx's Avatar
mmmmmm....
so cant use the old glue that was from light? They wont stick together huh? this is my last question...no more!! damn, I'm trying something new to my oem headlights not the jdm headlights.
Old 11-03-2006 | 07:55 PM
gftgrill's Avatar
in short, no. there just won't be enough glue left to create the same seal that it had before.
Old 11-03-2006 | 08:06 PM
S14 n Tsx's Avatar
mmmmmm....
^^ thank you so much..
Old 11-03-2006 | 09:40 PM
pizzaman555's Avatar
I just used the same glue and put them back together.
Old 11-03-2006 | 09:42 PM
S14 n Tsx's Avatar
mmmmmm....
what you mean by same glue? the original factory glue that was on?
Old 11-04-2006 | 01:32 AM
kaliraver69's Avatar
i went to an Acurazine meet and I met a guy who had a 7th Gen Accord and he had resealed his OEM headlights 3 times and reused the factory glue that came with the headlights and he had no condensation or anything on them.
Old 11-04-2006 | 01:53 AM
S14 n Tsx's Avatar
mmmmmm....
Nice....thank you!
Old 11-04-2006 | 10:41 AM
Yeah ive been going for like 7 months now useing the factory glue and have no problems so far.
Old 11-05-2006 | 02:22 AM
S14 n Tsx's Avatar
mmmmmm....
good hear that...
Old 11-05-2006 | 11:28 PM
TSX420J's Avatar
CarbonGreyPearlEbony
Hope this turns out well, keep us posted. I'd like to do some mods to the headlights but I am a p^$$y. The best part about it is that they already have some condensation in the inside bottom corners. I am debating on saving up for 06 jdm lights or tampering with the originals.
Old 11-05-2006 | 11:57 PM
S14 n Tsx's Avatar
mmmmmm....
I say go with 06 JDM headlights...
Old 11-06-2006 | 04:46 PM
S14 don't you got the 06 JDM headlights?
Old 11-06-2006 | 05:13 PM
S14 n Tsx's Avatar
mmmmmm....
no sir. I got the 04-05 one..
Old 11-06-2006 | 10:45 PM
No sir, hahahaha Damn I guess being 25 means am old now or something. HAHA
Old 11-06-2006 | 11:24 PM
S14 n Tsx's Avatar
mmmmmm....
hahahaha!! actually no.. I use against my friends a lot too. You are not old, still young my brother.
Old 11-06-2006 | 11:31 PM
iamhomin's Avatar
04 remembrance
Old 11-07-2006 | 12:11 AM
S14 n Tsx's Avatar
mmmmmm....
Originally Posted by iamhomin
wtf??? lol
Old 02-05-2007 | 07:56 PM
yungwunn911's Avatar
-Mike
did you open your headlights?
Old 02-05-2007 | 08:09 PM
S14 n Tsx's Avatar
mmmmmm....
yes, I did and its pretty easy..
Old 02-05-2007 | 09:16 PM
-Mike
what you do? you got picS?
bluetl04
08-16-2016 02:49 PM
h22lude
09-27-2015 06:22 PM
ceb
ILX
09-27-2015 10:56 AM
Quick Reply: How to crack open the headlights?
