View Poll Results: If hondata made a K pro would u get it?
No doubt of course I would
53.85%
Maybe
38.46%
No
6.15%
hell no
1.54%
Voters: 65. You may not vote on this poll
Hondata...would you???
Old Apr 18, 2006 | 03:10 PM
Stokeless_TSX's Avatar
Stokeless
ok who would get the Kpro its hard going through all the threads trying to count it up so lets just start a new one and see how many we can get.
Old Apr 18, 2006 | 03:48 PM
Tsx536's Avatar
Rep'n Taxbrain.com
I would buy it in 10 seconds flat
Old Apr 18, 2006 | 03:58 PM
rmpage's Avatar
Drives With Hands
We'd have to hope for one for the AT though. Or else we could just use two different ECUs, one to control the transmission, like some RSX guys do.
Anyway if something came about that I could use I would probably do it.
Old Apr 18, 2006 | 04:37 PM
chuson's Avatar
T.DoT P.I.M.P. lol
I will jump on it too~!!!
Old Apr 18, 2006 | 05:07 PM
joerockt's Avatar
Just dial 1911
Whats a kpro
Old Apr 18, 2006 | 06:18 PM
Zasker1's Avatar
Polar Chicken
Is that like a facial cream? Can I buy it at WalMart?
Of course I would get it but I think we would first want to see what sort of gains one could get with bolt-on's and kpro. Most of us dont have a wad like Kenny to get a Super Charger installed on an AUTOMATIC.
Old Apr 18, 2006 | 08:09 PM
rmpage's Avatar
Drives With Hands
The RSX-S can make some serious power with a Kpro. Intake/long tube header/catless exhaust nets 30hp after a good tune.
Old Apr 18, 2006 | 09:25 PM
Reach's Avatar
I would do it, beyond a doubt. For now I gotta find a few days to get my ecu over to them for the reflash but i would jump on a k-pro if available.
I'm putting so many miles on my car and I like it so much I'm thinking it may be around for far longer than I initially planned, and it would be worth it for the long run, re-tuning as I try new parts and all.
Old Apr 19, 2006 | 12:00 AM
raheel616's Avatar
id get kpro
Old Apr 19, 2006 | 02:59 AM
Chris_F's Avatar
I'd be in heaven if kpro was released! *drool* others would be too no questions asked. Hondata what are you doing!?
Old Apr 19, 2006 | 10:36 AM
waTSX's Avatar
Have camera, will travel
I'd certainly consider it. Wouldn't have any idea how to tune it though. However, JTso does live in my area
Old Apr 19, 2006 | 11:55 AM
Black_6spd's Avatar
VSA Rocks
30hp is NOT a good example of "serious" power from the Kpro. We get 30 hp with just R/H/I:
The Kpro would allow us to have more FI options, internal builds, etc. If you're looking for just bolt-ons and optimizing the stock internals, a Kpro isn't really needed.
Old Apr 19, 2006 | 12:04 PM
JTso's Avatar
Not true. One good example is the Hondata reflash, which is a reprogram of the stock ECU. The Kpro will allow fine tuning and optimizing those bolt-on components such as cams, header, intake manifold and throttle body. etc. The one size fits all reflash program can only do so much. It's not optimized for each individual setup.
Old Apr 19, 2006 | 12:22 PM
rmpage's Avatar
Drives With Hands
Read more of Hondata's research and you'll see that it's all about the intake cam angle. Long tube race headers will cause a loss of power with both stock and reflashed programming, mostly because LT headers love lots of valve overlap and stock/reflashed ECU programming doesn't allow more than 20 degrees of intake cam advance. With a Kpro, you can get over twice that, which allows you to take advantage of the scavenging/induction effect that a properly designed header brings to the table.
This is from Hondata's research using the TODA race header:
With the lower back pressure and better tuned lengths of the Toda Header, we also needed more cam advance. Advancing the intake cam allows for pressure waves from the exhaust to travel into the intake. At the right RPM range this can assist the movement of the intake charge into the cylinder.
Air travels into and out of an engine not smoothly, but in pulses. Think of blowing across the top of a beer (or wine) bottle. You will hear a note cause by the vibration of a column of air inside the bottle. An intake is the same. For a given diameter and length of tube, there is a resonance frequency. Where this matches the RPM of the engine, you will find a torque hump and lean spot. When we switched to an Injen cold air intake we found the resonance point to be around 4500-4700 rpm.
These dyno runs tested the following:
- Injen Cold Air intake
- Toda Race headers with test pipe (no cat)
- 45 degree VTC cam advance
- RBC intake manifold
- Hondata Heatshield gasket
At this point we switched the engine management to K-Pro with an adapter harness. The two reasons for doing this were speed and flexibility. Programming the TSX ECU is slow, allowing for only dyno 2 runs per hour. The second reason is that we wanted to move the cam past 20 degrees and up to 45 degrees advance.
Note the dramatic differences between the reflashed ECU and the Kpro using the LT header.
http://www.hondata.com/tuning_the_tsx.html
Old Apr 19, 2006 | 12:26 PM
Black_6spd's Avatar
VSA Rocks
Agreed that a "one reflash fits all" would leave some HP untapped for bolt-ons (I/H/E/IM/TB). But in your opinion, how much power do you think we'd be missing out on if we tweaked the timing, cam angle, fuel maps, etc for bolt-ons? 5hp? 10hp? While I'm sure we'd be missing out on some gains, a $1000 Kpro wouldn't be worth 5hp to me. Hopefully your experience tells me otherwise since I haven't had ANY experience in tuning.
On the other hand, if you were building the internals (cams, springs, valves, pistons, etc) theres no question that a programmable ECU would be needed.
Old Apr 19, 2006 | 12:32 PM
Black_6spd's Avatar
VSA Rocks
Never mind -- rmpage answered my question. A WHOLE LOT of power.
I stand corrected: Yes, I'd like a Kpro (even if I get just bolt-ons)
Old Apr 20, 2006 | 09:17 AM
daddydliv's Avatar
Faster, please.
It would depend on the cost of upgrading from a reflashed ecu and how much gain there would actually be. Therefore I say maybe.
Old Apr 20, 2006 | 09:35 AM
JTso's Avatar
A programmable ECU is simply a tool which allows you to make changes to certain ECU settings. It doesn't automatically provide any gain without the proper tunning to your components or setup. Unless you are experienced with performance tuning or interested in learning (very rewarding), the task is usually done by a shop or tuner with access to a dyno. It means additional labor time on top of the Kpro. Another option is to use a pre-tuned program with similar setup as yours.
Old May 6, 2006 | 09:53 PM
dainjo's Avatar
it's likely that I'll have it done.....my bf deals with Hondata and does tuning.
