Hondata heat gasket valuable?
Faster, please.
I'm wondering if there is any significant benefit to adding the Hondata heat gasket. I know several people here have one but haven't gotten a definite answer as to whether or not there are any performance gains. I understand the theory behind it but is it really something I'll feel or just a waste of $60?
I'm having a few things installed next week by Chris Rado's crew (World Racing) and they didn't know much about it saying it was probably mostly hype. Just wanna know if it's worth having done or not. I'm particularly interested in anyone who has ONLY the gasket as an engine performance mod, but will look forward to any input from those that have one installed.
Gotta get some sleep but I'll check back in the AM for any replies.
![Salute](https://acurazine.com/forums/images/smilies/salute.gif)
Bye TSX, hello domestic?
I can't say the difference it made on my car, as I haven't dyno'd with it. But Hondata makes a ton of gaskets for a ton of cars and other people have had great results, so I see no reason not to expect the same. Actually $60 for a mod that could net 5hp is extremely cheap, considering an exhaust is $700-900 and worth probably 3. After the CAI, the gasket has to be the next most effective.
Über Geek
Originally Posted by sauceman
…you will also have to do the TB coolant bypass modification. Then I guess it would help enhance the CAI's effect.
Moderator Alumnus
The Throttle Body is the extension of the intake manifold. It regulates how much air will be let in, depending on how hard you press on the gas. There is a line of coolant that goes through it to heat up the air quickly on cold starts. It is a feature that just seems to help improve driveability, but I don't know what else if anything.
The main problem is that once the engine is heated, the coolant line will give out too much heat, thus heating up the air coming through the Throttle Body. The same thing happens with the intake manifold. It gets heated up by being bolted on to the engine itslef, so it gets pretty hot.
So having the heatshield on, with the coolant TB bypass, you will get some cooler air in the engine. Cooler air is denser and allows for more fuel to be injected in order to keep an ideal air/fuel ratio. More fuel and more air means more power. To the effect of about 1% for every 10°C of cooler air.
Hope it helps
Hope it helps
Automobile Aficionado
Hope it helps
Hope it helps
Faster, please.
Thank you for all of the input. I had figured all along that I'd do it since it's only $60 anyway, but when they sounded skeptical it planted a seed of doubt in my head (they are a professional racing crew).
Do you mean driveability only while the engine is cold or overall? And would I have to drive much differently than my normal cold engine routine?
BTW I am having at least 3 things done next week anyway - Injen CAI (black), Comptech Short Shifter, Comptech rear sway bar.
Dont imitatate/duplicate!
so what does this hondata gasket do. how long does it take to install and will it effect warranty?
the tsx is my first honda and my first car.
still learning here...
Moderator Alumnus
It's a heatshield: it keeps the heat from the engine from transferring to the intake manifold. I don't see how it should kill your warranty, but check out just to be sure.
so the hondata gasket boosted your hp by taking heat out of the intake?
Faster, please.
I'd better stay away from the bypass mod as we do get freezing temps here in the winter quite regularly. However, does anyone know how effective the gasket is without the bypass (i.e. is it worth the $60)?
Moderator Alumnus
Well, as said in the thread, it is an easily reversible mod, so you could run with this mod in summer, and once you arrive later in fall season, at the same time you change tires for winter tires, you switch back to stock configuration and change your CAI to SRI at the same time.
I might consider doing this if I finally decide to install an Injen on mine.
Jtso, are you able to quantify the gains with the CAI/heatshield/TB coolant bypass?
I'm planning on another dyno run pretty soon for a hp gain comparison. One important thing we must realize. The most noticeable gain is prior to heatsoak. Once components are heatsoaked, the Hondata gasket, TB bypass, or the CAI won't provide much benefit until temparature is stabilized agan from air moving through the intake, tb, intake manifold. etc. Prior to my dyno runs, I usually hook up to an OBD2 scanner to monitor coolant and air temp to make sure the engine is up to operating temperature and temp condition is consistent (well, as much as possible). Otherwise, the results can be skewed by the different variables. I would be happy to see 3 hp gain.
wuts this throttle body bypass?
can you buy this off hondata too?
how much is it?
and how much hp does it give you
how much is it?
Port & Polish Everything
Also, which modification are you most satisfied with?
I recently ordered an aem sri, because my oem air intake resonator was cracked from a slight fender bender, which I think is a better investment than to replace the cracked resonator.
iamhomin, who's eagerly waiting for the shipment to arrive.
Originally Posted by outersquare
huh, if anything i would have figured the IMG and the bypass help reduce the effects of heatsoak.
Originally Posted by iamhomin
Hey JTso, I pretty much read all your threads regarding aftermarket modifications and I'm quite curious to know what your current hp/tq is.
Care to share?
Care to share?
Moderator Alumnus
My header install seems to have the most significant gain but the K&N offers the nicest sound effect.
The last dyno run yielded 179.7 hp, 156.6 tq with a relatively tight engine. I'm hoping it will do a little better the next time.
JTso...
do u mind telling me what kinda careeer do you pursue? something related to auto mechanics? or you are just soo crazy about cars!?![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
haha...i am sorry that i asked such a weird question, just that regular people i know don't know that much about cars
Haha.. I'm just a car enthusiast who really enjoys working on cars ever since I took autoshop back in high school looong time ago.
However, there's no way I see myself working on other people's car everyday as a mechanic, but I did dream about owning a shop with a dyno for performance tuning.
![Loco](https://acurazine.com/forums/images/smilies/loco.gif)
Hi.. i did a search..and came up with this thread. How exactly does one install a hondata heatshield? and would it be smart to get one before winter season...?
Moderator Alumnus
And I don't see an issue with installing it even before winter. Anytime is the right time.
Stokeless
Johnny...have you redyno'ed yet? let me know some numbers i have to install my gastket and TB bypass still...along with my oil catch. Im still waiting on hondata kpro so i can slap on the turbo...arg im almost so tired of waiting i might just get the comptech SC till i can turbo it and build the engine at the same time...=( i have no patience grrrr
InFaMouSLink
10-27-2015 06:52 PM
