Hondata ECU Reflash is out ** '05 MT & '06 AT/MT now available! p.37**
#162
Drives With Hands
I'm curious how much companies like Comptech do with their reflashes for their products. Specifically, whether they do the bare minimum to make the engine operable, or do they tweak it a bit to get the most out of it with the FI like Hondata does with NA. If it's the former, that really sucks to bolt on a $3000 compressor and have much less of a gain than you could if the ECU received maximum tweakage.
#163
This dyno compares the wheel power of a supercharged TSX engine in an EP3 Civic to a supercharged K20A3 engine (the previous and stock engine).
This was done on the same dyno as the NA TSX.
About 140 hp more than stock and 75 ft pounds more peak torque.
The owner's website is here http://www.mrrocket.com/ep3.htm
This is an example of the R&D we do. The data here will be fed back to the supercharger manufacturers to help them develop products for the TSX.
The car runs a non intercooled JR supercharger from an EP3 modified to fit the TSX head.
- 650 injectors
- PRB RSX-S exhaust cam (smaller than a TSX exhaust cam)
- PRC Integra type R intake cam (bigger than a TSX intake cam)
- VTC mechanism modified to allow 40 degrees advance instead of 25 degrees
- EP3 throttle body
- 650 injectors
- EP3 throttle body
#164
Originally Posted by Stokeless_TSX
well if you look at the link its says K20a3...so I don't think its for the TSX engine.
could be the third dyno they did... very unlikely there would be a 3 just randomly there, is that even an engine?
#166
Power is at the hubs. The wheels are removed for this dyno, which typically dynos 10hp higher than a Dynojet. As has been said before look at the differences in power and torque. You cannot accurately compare different dynos' power figures.
#167
ok so it was the Si motor vs the TSX motor with the same supercharger and pulley set???
When you supercharge a larger capacity engine you must spin the blower faster to maintain the boost level.
Here is the boost curve which ranges from 5 pounds at low rpm to 10.5 pounds at 7500 rpm. Solid yellow line supercharged TSX. Dotted yellow turbocharged RSX boost curve.
#173
Special-K
184.6 with just I/E thank you =)
#174
Stokeless
Originally Posted by PrecyseStylez
184.6WHP at what RPM?? thats the question! And what does your power curve look like before you hit the 184.6WHP?? Probably nothing near what a tuned re-flash looks like...thats a whole different beast
#175
I can't wait to see how the reflash changes day-to-day driving. With the 5AT I find that it takes a hot second to get on cam. With the vtec engagement set to 5000 rpm I think we will definitely enjoy a better day-to-day driving experience. I can't wait!!
#176
#177
Audi Driving Snob
Originally Posted by domn
I was thinking the same until Dan set me straight. This flash really doesn't change the car much until 5K. How often do you rev to 5K? Not that often from what I remember in my day to day driving.
FOr me this looks to be a great mod, pending some user verification. THe tsx craves more top end power, but I wasn't willing to sacrifice any torque below 3k rpms as that's where I spend most of my time on the freeway cruising. looks like hondata can offer what I want.
#178
id hope u wouldnt be reving up to 5 grand every day..... you would be wasting a ton of fuel, now if hondata made the tuning somehow adaptive, it would know hey the throttle is to the floor change over to racing or something of that sort, and when your putting artound town under 3 grand ure getting better fuel mileage
#180
Audi Driving Snob
Hmmm, your right about the tourque. I was thinking HP.
:patientlyawaitsdynoswithoutheader:
For me it all comes down to what the mod makes without the header.
#183
Originally Posted by sauceman
I'm tempted to believe it would be almost as much.
From the Header dyno's we've seen thus far I would agree. Probly 5-7HP extra. But in the end
Link To Comptech's TSX Dyno Page
#184
Audi Driving Snob
Above 5k even with just the header you get a nice torque bump on the high cam. (stock 6k) Who knows what magic hondata can do without it. You will probably see similar peak HP figures but less area under the curve.
#185
Moderator Alumnus
But then again, maybe the stock ECU couldn't make good of the header, whereas the header could in fact be a critical part of the tuning of the reflash.
Then again, the 5000rpm high cam don't have much to do with the header...
Edit, Tinky beat me to it.
#186
#187
Photography Nerd
So many questions... can't wait until we see some dynos. How many of the guys that are jumping on the hondata bandwagon will have before and after dynos?
#188
Photography Nerd
Originally Posted by JTso
That's the reason I went to something more effective despite it's popularity. You can clearly see gain across the entire rpm range, not just in the end.
#189
#191
Photography Nerd
I'm all about working with real data. If I can get my spare ECU match up with my original key and immobilizer, I will spend the $ on the NA reflash just to get a comparison, even it means I have to pay again when the TC setup reflash or (hoping) the K-pro is available.
I'm really still not clear on what hondata said about the ECU and immobilizer matching up. I think they implied that you could get your dealer to do this but what does that mean? Is it just a matter of them hooking up the ECU to a tool and copying some data from the immobilizer or is it more involved than that?
My car is leased and I'm not sure if I'm going to buy it out at the end of the term. I'd still be interested in the mod if I could get a second ECU and swap out.
#193
Audi Driving Snob
#194
Stokeless
Originally Posted by dzuy
to the hondata heatshield owners,
where did u buy from and how much?
#195
shoot.
i dont think it will be in by this week.
monday - car goes in shop, take out ecu
tues - ship out ecu to south florida performance
wed - ecu arrive at SFP, ship out to hondata
thur - hondata reflash, send to SFP
fri - SFP recieve. ship.
that means i wont recieve until next monday?
#198
some Questions
I am not familiar at all with the technical details.
I read the TOV article.
Questions:
1) How is fuel economy going to be affected ?
2) You guys are talking headers and CAI etc. -
How much good is this going to do on a totally stock car ?
3) I currently drive mostly local roads (40 mph), so my rev range is on average up to 4K. Do you think I can benefit from this reflash ? Can I get more torque ?
Thanks for your insights
Questions:
#199
Stokeless
nah. i heard you shift like a grandma.
:troutslap
:troutslap
#200
Audi Driving Snob
What they mean is you need a matched set of key, imobilizer and ecu. So just having a spare ecu won't work, you need a set of keys and imobilizer all matched with the same data on it which probably won't be cheap.
