Help, RT CAT Install
Polar Chicken
I am trying to get my CAT in before it is dark, I got it today but there were not instructions specifying weather or not I needed to use the old gaskets off of the OEM Cat to connect to the cat back exhaust. Should I pry this gasket out of the CAT or just not use one? Where it connects to my DC Header is clear enough but I am not sure what to do with the back. I would rather not guess and test as that takes time with a hot part.
Originally Posted by Tsx536
I would definitely use a gasket. Either buy a new one or reuse the old. PM Moda_way or JTso if you need an answer ASAP.
Edit: There's Moda_way
That's just funny!
I just got done ordering my Comptech Headers, header gasket and post-cat gasket. I replace everything just in case (actually b/c I'm OCD about it), but I can tell you in most cases it isn't necessary to get a new gasket.
Originally Posted by Zasker1
So I got the install done, I left the post cat gasket out as it would not mate up well, but I reused my gasket from my dc-header.
Have you check for leaks? How does it sound? COME ON MAN!!! I get mine tomorow and I just gotta know.
Rep'n Taxbrain.com
...AND??
What do you think? Did you get a chance to drive it yet. The big things I'm wondering about is how much louder it is and if you lost any low end power.
Polar Chicken
I would say there is in increas in low end power, and the volume increas is realy quite small, it sounds tough down low, like if you had a Cat Back Ehaust but I would not say it is loud. I dont notice it with the windows up.
IIDXholic
10-08-2015 07:53 AM
