Front sway bar question
TSX-Black Bolt
I want to replace the front sway bar bushings with polys...
Does any one know how to remove the rear bolt on the bushing cap?
I can't get to it with a wrench or a socket.
Not as easy as the rear thats for sure...
Hey, maybe someone knows who's been on the board longer... Is there any sort of repository on the site for information like this? To store all sorts of DIY-type information, including the sway-bar info?
Bye TSX, hello domestic?
TSX-Black Bolt
Originally Posted by tsXgtp
Can you add the part numbers of the bushings?
I have not check to see if they are going to fit yet.
The buckets came with zerf fittings..so you can lube them when needed.
But the ones i got for the rear were universal too, and they fit just fine.
The buckets have sloted holes so you can poistion them where you need them.
I have them on the rear for a while now ...with no sqweaking or with any other issues.
I expect the same from the new front replacements.
