Originally Posted by CGTSX07
just for everyones info, zipties work well also in addition to the stock oem hangers. I just added two to each hanger and adjusted the mufflers to where I wanted them. this also stiffens up the muffler so it will not sway back and forth as easily.
Will the zipties melt eventually?
I have these hangers on my Tanabe MT exhaust and like them a lot. Only very minorly uneven hanging. I am sure that if I'd left the OEM hangers on it would be worse. The aftermarket ones are definitely stiffer/more solid.
this is all I did:
http://lh3.google.com/geoffreymchu/R...JPG?imgmax=512 All I did was push the muffler tip in the direction i wanted while pulling on the ziptie at the sametime in order to tighten it. I did this on both because I wanted both higher and centered. I also used two zipties on each just for better support. The hangers do not heat up so the zipties will not melt. http://lh5.google.com/geoffreymchu/R...JPG?imgmax=512 |
The hangers do not heat up so the zipties will not melt. |
nope, there is no melting whatsoever. yesterday would've been a good test since I drove 2 hrs straight two ways and there are no issues with melting.
