engine cover question
OK--so the valve cover and spark plug cover, (JDM) is the same that fits the RSX....does that mean the engine cover for the RSX fits the TSX too. Look at the attached pic!
http://www.modacar.com/products/Acura/RSX/MODAVAC
they are not the same and thus will not fit. if you want an alternative color you can get the same one as ours but black. they have those in the 03 honda accord i4's. you can check a parts website and order one.
As an owner of an RSX in addition to having a TSX, I'll tell you. The ITR ones won't fit. The JDM covers have a different fit than the ones for the cars we get over here. Even the wire cover has to be changed out.
yes, that is where I found the info from about the valve cover, was from aj-racing.com, recommended by inspire-s. The valve cover and spark plug cover will fit....however i have learned that the engine cover is different...three separate pieces...sorry for the confusion
sockr1
10-01-2015 01:31 AM
wusty23jd
09-24-2015 11:41 AM
