DIY ....Counter sunk/ counter weight shift knobs
This would be a good DIY for someone who has access to a metal lathe. Just practice and patience is required. Skill could be usefull for better results ![Too Cool](https://acurazine.com/forums/images/smilies/toocool.gif)
So I started off with a stock of steel...
![](http://i223.photobucket.com/albums/dd120/gtp_98/IMG_0524.jpg)
Started machining it down to size, I didnt take any measurements at all, just went with what would feel comfortable in my hand.
![](http://i223.photobucket.com/albums/dd120/gtp_98/IMG_0536.jpg)
once I got the thickness I wanted, I drilled the hole that I will counter sink and then thread it with 8x1.25 mm tap. I counter sunk the knob to make it sit as low as possible.
![](http://i223.photobucket.com/albums/dd120/gtp_98/45.jpg)
Now I tapered the bottom end of the knob
![](http://i223.photobucket.com/albums/dd120/gtp_98/IMG_0539.jpg)
after doing some finishing runs to get a nice finish I cut off the knob from the steel stock.
![](http://i223.photobucket.com/albums/dd120/gtp_98/IMG_0545.jpg)
I put duct tape on the finished side and put it back on the machine so I could finish the top of the knob.
![](http://i223.photobucket.com/albums/dd120/gtp_98/IMG_0547.jpg)
here it is fresh off the machine, weighs over 400 grams.
![](http://i223.photobucket.com/albums/dd120/gtp_98/IMG_0549.jpg)
![](http://i223.photobucket.com/albums/dd120/gtp_98/IMG_0551.jpg)
After a few coats of clear coat , here is how it looks in the car. I know having a counter weight shift knob on an A/T is useless but its nice and solid. i love how it sits so low.
![](http://i223.photobucket.com/albums/dd120/gtp_98/IMG_0558.jpg)
Someone stole "My Garage"
Nice! Back in the early 90's I used to love going to woodshop class to use the lathe. So many options and so much originality can be made in minutes.
Looks good although maybe a slightly more gradual taper to the bottom would make it look a bit less block-y...? Either way I think it looks great man, nice work!!
Hines57
09-24-2015 01:58 PM
2006, acura, counter, countersunk, counterweight, counterweighted, diy, knob, knobs, machined, machining, make, maven, shift, tsx
