DC Header and Random Technology Cat Install on an '04 TSX
So I have a 2004 TSX 6speed... and I am not starting to do power mods on it . I feel like I am joining the party a little late, but oh well. Better late than never. I ran into a problem, however, installing (or actually uninstalling) the header. When I went under the car, as you can expect, all of the bolts were covered in rust (live in Raleigh, NC). The O2 sensor, in particular, was rusted pretty bad. I put the 7/8" wrench on it (like Jtso suggested) and started trying to take it off, but instead of twisting the actual screw (nut, bolts, whatever), I was moving the whole exhaust! The flex pipe looked like it was about to break. (haha ok, that is a bit of an exaggeration). I sprayed WD40 on it to maybe loosen it up. I am going to let it sit overnight.
Any more tips on how to get the sensors off of the header and cat? or get any of the bolts off of the exhaust?
Should I use PBblaster instead? I didn't have any on me, but don't they do the same thing?
I did a search, and ofcourse I found all of the writeups, but I just wanted to make sure that I was doing this right, don't want to break the O2 sensor.
Thank you for any tips in advance
im doing the same thing you're doing well except i got comptech headers..anyways im getting mine installed fri i couldnt find a local garage in my town that would do it so i asked the acura in youngstown ohio to do it for me and they said they would..thank god cuz now i dont have to worry bout some guy whose been working on ford tauruses his entire life messing around with my black stallion...good luck on your project! let me know if you get a CEL with that cat..im hoping i dont get one!
I put the install on hold because I am in need of new bolts. But How much is a O2 sensor socket? Is it really necessary? Is it easier to take off the sensor with it than a 7/8 wrench? I bought all of my parts used because I wanted to save money, so I'd prefer to not buy any unnecessary tools, ya know? BM ftw!
OoKrnBoi0331oO - what jtso said
why dont you just unplug the sensor and remove the whole assembly out of the car.. once its out you can get someone to help you (leverage and long bars will help remove the sensor), for the bolts the only ones i had a problem with are the cat bolts (had to take my dremril and cut one off) not sure if youre having issues with the header ones that connect to the block i am only assuming it was the ones connected to the cat
cycdaniel
12-17-2019 11:58 AM
ExcelerateRep
Sponsored Sales & Group Buys
01-06-2016 10:59 AM
ExcelerateRep
12-11-2015 01:58 PM
