DBW with K-Pro Update!
#81
I don't know what's going on with this, but it seems the 7th gen accord forums have a guy with a k24a4 5at accord to use an Kpro'd RSX ECU through a harness. Apparently its not anything weird, or convoluted; its very possible. Seems he (cstyleaccord) has 600+ hp going through some sort of FI+kpro.
#85
Special-K
Im actually buying an 04 rsx-s ecu with k-pro next week! I've been busy and havent had anytime to mod or look for mods until now. I was gonna try and see if Marcus from heeltoeauto.com could get that harness from hytech but Marcus told me to get ahold of them myself... So thru email i've been going back and forth with John from Hytech. At first i was discouraged because he told me that inorder for the harness to work i would have to disable DBW and get a cable throttle body!.. But from the write up Marcus made about that harness it never said anything about having to use a cable throttle body. So John told me he would find out more info and he did. Wrote me back and said that the only thing that wont work is cruise control.. and that everything else is a go, meaning AC/guages/DBW/etc. He told me that its gonna take 6 weeks or so because they have to test it out when they have it ready to make sure there isn't any bugs. He said from what he knows, only the cruise control will not work and that he'll keep me informed as to when they will have a working prototype.
NOW!.. hopefully it doesnt take that much longer than 6 weeks.. im in no crazy rush but i want to test it out. Im gonna have to send my ecu back to hondata so they can flash it back to stock or buy one from one of you guys!?...
#89
Originally Posted by feuss2
bump!
what parts do you have now???
#91
Special-K
For the setup you're talking about, why would it matter what program was in the TSX ECU?
#92
10001110101
Originally Posted by DAYTA
Why are you interested anyway? Don't you already have ~270hp from Hondata+K&N intake+heatshield gasket?
https://acurazine.com/forums/showpos...&postcount=398
Its probably more considering these new mods:
Resonator removal:
Vented the horsepower-robbing fog light covers:
#93
10001110101
Originally Posted by PrecyseStylez
Is this a trick question?.. Well first off if anyone is planning on doing cams/pistons/race header/etc. then you'll need some type of engine management. Im not actually gonna go all out right now because its very expenisve. So what i am gonna do right now is 06 TSX cams/rsx 50 degree vtc gear/rbc intake manifold/hytech header and maybe cat/k-pro with harness and rsx ecu/port the head (and installing springs and retainers) and hone the block and a mild 3 angle valve job. Should make nice gains with this set up and all thats left to do is mainly build the block. I have to take steps.. Cant make all this complete without engine management though.
I would think your local dealer could put your ECU back to stock if you really wanted that. The Hondata paperwork tells you its your responsibility to make sure their program isn't overwritten...
Hondata's tuning the TSX article also mentions the risk of valve/piston contact with the 50 degree VTC... Hytech sells one that's 45.
Are you doing any of this work yourself or do you have a shop in mind?
#94
T.DoT P.I.M.P. lol
1 Post
Not a trick question... If the TSX ECU is just running accessories and the RSX K-Pro ECU is doing the engine management then why would it make a difference which maps are in the TSX ECU? The TSX ECU with the Hondata program runs all the guagues, VSA, etc... Why would you put it back to stock?
Basically, he needs a regular TSX ECU, pair with a RSX ECU in order to run the K-Pro properly. Since he no longer need the reflashes, he would just like to replace with a non-flash ECU for this purpose. It is NOT cost efficient to run both K-Pro and Hondata Reflash ECU @ the same time, he would trade it for more $$$.
As for the valve/piston contact, it is not an issues once they all swap to aftermarket parts.
For PrecyseStyles, why don't you just take our your TSX VTC and adjust it?
#95
T.DoT P.I.M.P. lol
1 Post
Good memory!
Resonator removal:
Resonator removal:
#96
10001110101
Originally Posted by chuson
lol
#97
T.DoT P.I.M.P. lol
1 Post
How many reflashes and issues are you referring to???
Reflash is a off-the-shelf tuned engine management that Hondata provide, it's not programmable, and it's written on the TSX ECU.
K-Pro is a self-tunable enginer management, which is utilizes all your components further than Reflash, hence better tune/gain over Reflash.
In order for PrecyseStyles to use K-Pro, he needs TSX & RSX ECU to get it to work. The RSX ECU will handle the engine management part, and pair with the K-Pro; where the TSX ECU will take care of the non-engine related part. Since his TSX ECU will no longer be handling the engine, his reflash is useless. Therefore, he's asking for a trade w/ member who has a 04 6MT non-flash ECU, that way he can get some $$$ back.
#98
Good memory!
Resonator removal:
Resonator removal:
I was calling your bullshit of having 270hp from mods that would yield maybe 25hp at most. I can't believe you're still trying to play it off like you're telling the truth!!!
#99
WTF~! 270hp by doing that??? lol I wanna see the original thread... what's all these about????
He posted this crap in the "TSX Dynos" thread at the top of this section:
https://acurazine.com/forums/showthr...&page=16&pp=25
Check out the bottom of pg 16 to see it all unfold......
#100
10001110101
Don't worry, he's completely full of shit. There's a reason why he only posted a single reply from the thread...because everyone else called his BS. Also, if you look at his graph, someone pointed out that it was made on MS Paint .
https://acurazine.com/forums/showpos...94&postcount=5
Please calm down!!!! Let's not jack the thread with this nonsense...
Its about DBW w/ KPro. One question, if you going to stay N/A would it make sense to see if Hondata will make a custom flash for the 45~50 degree VTC, etc? Maybe could start with the 06+ map as a base?
#101
It was a joke!!!!! Just like this:
Dude, how were we supposed to know that??? The post you linked wasn't in red text before, so we couldn't tell that you were trying to make a joke! Sorry about calling you out, but I definitely thought you were being serious. You never responded otherwise. Please use red text next time you're being facetious .
Back on topic, the whole problem with the reflash is that it's a static mapping. That's the reason why we want K-Pro - so that you can customize the fuel mapping/engine management. In other words, you modify/build the engine, put it on the dyno, and adjust the settings accordingly.
#102
Special-K
#103
I have an 07 tsx. Planning on running hitec header mandrel bent piping, and an RBC mani. With Intake. How much would it cost to have a custom k pro setup?
Its been awhile since I've tuned a car. Could we possibly run EMS? I'd consider it.
#104
where is my garage?!
1 Post
Ok, well its been since 04 that the TSX has been out.. so im not gonna wait another year for hondata to come up with something. This harness isnt even coming from hondata! They gave up on the TSX it seems.. well not to say the TSX but the DBW system. Another reason why there isnt any k-pro support for the new Civic Si's. Im not gonna use the entire 50 degrees.. with K-Pro you can adjust the degree accordingly. And then again im not raising the rev limiter untill i build the block so i'll continue to keep it at 7600 maybe even 7800..haha. Having the VTC set a 50 degrees wont hurt the car unless i over rev/miss shift but like i said, its gonna be set lower than 50 degrees. So since I'll have engine management there's no need to tamper with the TSX VTC, plus i got the RSX VTC for dirt cheap.. so why bother? Maybe when i take out the TSX VTC i'll have them mech it to 45 degrees and sell it to one of you guys?
there was a short blurb on a k-series.com article talking about how hondata is working on the latest Si's and may have something in 6 months. whether it's k-pro or simply a reflash, it doesn't really specify. but i'd imagine cracking the newest civic would take priority over anything else given its popularity and large userbase. hopefully if this yields results, it'll benefit other hondas/acuras.
#105
Special-K
#106
T.DoT P.I.M.P. lol
1 Post
#108
T.DoT P.I.M.P. lol
1 Post
Originally Posted by EuroRuben97
Is there absolutely no way to tune this fawkin car?
Tune- Yes. Hondata K-Pro and some harness. With a loss of regular use features, such as guage, ABS, VSA, Cruise, and A/C.
Pre-Tune- Yes. Hondata Reflash. Not tunable.
#109
Special-K
Depends on what you mean by tune, and what function you would like to remain in the car.
#110
T.DoT P.I.M.P. lol
1 Post
Thats not 100% true.. Im told that the harness will only effect cruise control.. everything else will work. .....
I dont think just by changing the vtc from 25 degrees to 45 degrees will yeild any gains without tuning something else (fuel/timing/etc.). Hondata should've made a tune for a 45 degree VTC to go along with other mods.. something like how they had #1,2,3 and 4 tunes for the RSX-S..
I wish they had different reflash... maybe I should send an e-mail to suggest... lol
#111
10001110101
I e-mailed Doug @ Hondata... The 20 degree VTC movement is a software limitation. It's not possible to make a reflash to do more. He also said there was no hope for a K-pro for the TSX...
Swapping VTC's will just mean that there is no mechanical stop to preven more than 20 degrees of movement. It is necessary to have an ECU that will allow you to program that...
I'm pretty curious about the Hytech setup now... (how they reflash to take advantage of the 45 degree cam in their package...)
#112
A DiRTBAG decal on my
#113
T.DoT P.I.M.P. lol
1 Post
If it's software limitation, then nothing we can do about it. I think we need more company to whack our ECU, more competition means more efficient....
#114
10001110101
I posted the question on Hondata forum but no one replies yet.
There's the answer!
Agreed.
Does anyone know why this won't work for the tsx:
http://hondata.com/kpro_element.html
#115
Ticket Slow Drivers
Or something like this: http://hondata.com/s2000kpro.html
I'm sure there are a number of reasons...
(Although I just bought the reflash!)
There's the answer!
Agreed.
Agreed.
#116
Special-K
#117
1 Post
assuming the initial setup of the RSX K-pro'ed ecu/harness/TSX ecu works, does it matter what year TSX you have or would it work for any year?
just wondering if the fact that the 07+ ecu's aren't reflashable and different from the 04/05's and the 06 has any impact.
and if this set up did work, are there any parts you need to change within the engine to make it work vs. whatever standard bolt-on mods people have on their cars now? or is that what you're basically trying to figure out. apologies if these questions are n00bian in nature. ecu tuning is totally new to me.
#118
1 Post
hey chuson, they responded to your post--
Posted: Wed Feb 06, 2008 10:18 am Post subject:
The throttle body will make no difference to the tuning - the flow of a system is determined by the greatest restriction, which is not the throttle body with the TSX intake manifold.
The CAI does make a difference as it alters the intake pulse effect, but the reflash was made with a CAI in mind.
The reflash does not advance past 25 degrees, so you won't see any changes by changing the intake cam gear.
#119
Special-K
