Comptech Ice Box and Hondata Heatshield installed
A big thanks goes out to Jtso for spending a couple of hours installing my modifications.
I decided to be different than everybody else and get the ice box. I wanted to keep a stock look but improve performance. The ice box is bigger than the stock air box and has increased air volume with no restrictions in the box itself. The resonator was replaced with a lower airhorn to draw cold air in just like a CAI.
I definitely have noticed better throttle body response and a smooth growl at WOT. It definitely sounds more aggressive but it not noisy in normal driving. The ice box paired with the Hondata Heatshield and Jtso throttle body bypass has improved the torque. I definitely need to do a dyno to see what positive results I gained.
Modifications to be installed...
Side by Side comparison...
OEM stock lid, notice all the restrictive parts in the box...
Comptech Ice Box lid...
Final product...
Final product...
Originally Posted by TSXDude
Looks good, I plan to get that too!!
Does the ice box uses the OEM lower air box and the OEM filter??
Originally Posted by mg7726
sigmachi, could you post an audio clip of the icebox?
i'm thinking of ghetto'ing it by removing the resonator, and dremeling out the fins on the oem airbox
Originally Posted by sigmachi96
Hopefully I'll get the same results from the Comptech Dynos especially with the heatshield.
Torque...
Horsepower...
Torque...
Horsepower...
But just looking at the torque: Only a 5lb-ft max gain. But with a dip at 1700-2100 AND 2700-3200? Hmmmm...
Maybe I'm out on a limb here, but couldn't one just alter the stock box with say a Dremel, by removing the "internal" plastic pieces that are absent on the Comptech box? Or is there something else to the design I can't make out on these pictures...
Might be an easy diy.
Originally Posted by ClutchPerformer
You posted two torque curves.
You must then buy a better filter (ie K&N). I guess you could do this and come close to the same results.
Hmm, max gain 5.6hp all the way up at redline. How much was the Icebox?
If I was to do a dyno, I would probably get slightly better results as I also I have the Hondata Heatshield.
I'll see what I can do about getting an audio clip.
Comptech Ice Box on a RSX
Originally Posted by batman
sigmachi96 did you guys take the front bumper off?
BoricuaTL
04-08-2016 01:08 PM
k6biv
09-10-2015 06:37 PM
