Cheap air horn for resonator removal
I have a 2006 TSX and removed the air intake resonator today. I found an inexpensive air horn from Parts Express that is dubbed as a speaker port tube. It fits perfectly in the rubber tube you are left with when removing the resonator. It is 3" diameter for the inside tube. It was about $10 shipped. They also sell through Amazon for around the same price.
http://www.parts-express.com/pe/show...number=268-322
I used a hose clamp to keep it secure. I also put some tape on the inside to smooth out the air flow as it has a ridge on the inside as it is normally designed to have a tub go inside of it instead of it going inside of something. It probably isn't necessary, but it never hurts.
OK, I guess I'll take your word for it, but...... a number of CAI/hydro-lock stories on this forum if I'm not mistaken.
^ if you retain the oem bottom portion of the box, there is a by-pass valve that will let water out. so long as you are not gunning the engine through a river, the water will drain out. i believe a user posted a video of this a while back to prove that the by-pass valve actually works and that its actually kinda' hard to hydrolock your engine with something like the comptech icebox...
cycdaniel
12-17-2019 10:58 AM
BoricuaTL
04-08-2016 01:08 PM
