Carsound Magnaflow high flow catalytic converter installed
#122
you guys are making this much more complicated than it really is. If you never will consider putting the oem cat back on, just do it the easy way and spend 160 and get yourself a high-flow cat at any muffler shop.
If you really want to keep the stock cat, then just keep the cat after they cut it off, and later on if you want it back on, just cut off the highflow cat and put the oem back on.
Noise will be increased a little with a highflow cat, a bit deeper but louder. Its easier to hear at lower rpms than before. But in the case of a testpipe/resonator, im sure it will make it alot louder, maybe even a bit raspy.
IMO i feel the gains were worth the money. Especially now, how the header and high flow cat completely fixed the hesitation i used to feel at vtec with hondata. Acceleration is alot smoother and consistant now. On the downside, i do think my gas mileage has decreased somewhat from adding this cat. I havent done any factual tests yet, but ive been noticing my tsx eating up more gas quicker than before.
#123
Originally Posted by MrHeeltoe
Yeah, I wanna dyno as well...but I am not sure what difference it will make on my stock car...I will try it, but just in case I don't show any gasins, who in the OC area has a TSX with a few mods who is interested in seeing if it will help? Looking for intake/heaer/exhaust, maybe a reflash was well.....Someone who has a dyno already preferrably.....PM ME!!!!! Don't clog this thread up. Serious people only.
And no it does not specifically mean you will get one for free! So don't ask!
There will be enough room engineered for the Cusco Type II bar, although this bar fits plenty well with the stock cat....so it should be pretty easy.....
These are not carb legal in CA. It is currently not legal to replace the cat on any OBD2 cat in CA! That does not mean I would not run one anyway though![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
We are MAKING our own flanges out of stainless steel material. The cat's are Magnaflow cats, same as the one used by the user in this thread...
let vwong do it!!!
he's about 30 min from the oc and he has hondata!!!!
#124
Photography Nerd
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
When I sell a car I generally don't want to sell it with a double hacked up OEM component. It's just begging to set off alarm bells at the mechanic when it goes in for inspection.
I'm still looking forward to this mod, it sounds like a cost effective upgrade with good results.
#125
Originally Posted by Dan Martin
If it cost you $160 and this set is $175, don't you think it's worth $15 so you can have the flexibilty of changing cats without having to go to a shop? ![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
When I sell a car I generally don't want to sell it with a double hacked up OEM component. It's just begging to set off alarm bells at the mechanic when it goes in for inspection.![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
#127
mrheeltoe,
i'm about this close [holds two fingers close together] from just buying the cat from you.
still want more details.
1. what pn cat are you using?
2. pics.
and believe you me, i will be revisiting the track w/ this mod.
2. pics.
#128
Former Sponsor
Originally Posted by dzuy
mrheeltoe,
2. pics.
2. pics.
DUDE, slow down a little...I am not sure why you think this is even a done deal yet.....I have not made these! I am not even starting until next week. Nothing for you to look at yet.
#129
#134
I already have the rear flange, gasket, extension pipe and cat ready. Just bought a pipe cutter today to make the final cut on the extension. Picking up the front flange tomorrow after work from my welding instructor, who offered to mill out the center hole for me (the hardest part without a machine shop). Just about to remove the cat off my car for some final measurements. With any luck, I will have one installed by the end of this week.
#135
Originally Posted by JTso
I already have the rear flange, gasket, extension pipe and cat ready. Just bought a pipe cutter today to make the final cut on the extension. Picking up the front flange tomorrow after work from my welding instructor, who offered to mill out the center hole for me (the hardest part without a machine shop). Just about to remove the cat off my car for some final measurements. With any luck, I will have one installed by the end of this week. ![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
i meant mr heel toe hahaha.
hey if you get measurements, can you send them my way thru pm?
thanks buddy.
will we see 14 sec slips from you? (or me?)
#136
Rep'n Taxbrain.com
![Ecstatic](https://acurazine.com/forums/images/smilies/ecstatic.gif)
#138
:troutslap
thanks buddy.
thanks buddy.
I will see what kind of result on the dyno first before hitting the track.
#139
My next mod? High flow cat.
#142
Here is my high flow cat with the O2 sensor at the factory location. It has true 2.25" ID in/out at the flanges. However, the header collector and stock catback are still only 2.00" ID. My next plan is to cut off the header collector at the 2 into 1 section, and weld on a new section with a matching flex pipe with the same 2.25" ID, and later follow by a new catback system. ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
#145
Drives With Hands
Well it looks sweet. So yours came with a bung welded in it already? Did you notice a performance difference?
Also, I think I'm going to grab a set of calipers and get the ID of the Comptech downpipe and Fujitsubo catback. They looked like 2.5" last I checked but probably aren't. I'm also curious to see what you decide to do about the catback.
#149
This is just a prototype cat to see what works. I'd be interested to see the new cat that MrHeeltoe mentioned and perhaps just buy one the next time.
#151
Originally Posted by Tsx536
Thanks for the update JTso. The cat looks great!
Did you come with a heat shield or did you get that custom done?
Did this new high flow cat make your exhuast louder?
#152
Drives With Hands
I notice that's an OBD2 compliant cat. The one I used wasn't. I wonder what the differences are, whether it's just the sensor bung placement, or if the catalyst is different?
#153
Former Sponsor
I think it is the sticker on the box that is different, That is my theory. I think it is a conspiricy....
#154
#158
So dzuy, what are you waiting for? ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
actually, i've been thinking alot about cars and modifying, and it's so much money.
i've spent so much money on buying "quality: products - comptech exhaust components, tein suspension....
is it really worth it?
i guess it's a little too late in the game i guess - i've spent so much already.
but still...so the cat is gonna cost a couple hundred bucks - but to be honest, i could enjoy the couple hundred bucks elsewhere.
we'll see.
i always try to resist the car urge.
:troutslap
#160
