can somone explain..
Old Jan 24, 2007 | 09:28 AM
TSeXaholic's Avatar
Can someone explain to me what an intake manifold gasket is?? Like whats the purpose, pros and cons...I am pretty noob with this item.
Old Jan 24, 2007 | 09:47 AM
moda_way's Avatar
Purpose is to isolate the heat exchange from the block (technically the block and coolant) and intake manifold.
Pro: Cooler intake temp
Con: PITA to install even with the amazing instructions provide here.
Old Jan 24, 2007 | 10:20 AM
psykotik's Avatar
the gains are not worth it in my opinion.. it helps but.. to have it installed isnt worth the trouble
Old Jan 24, 2007 | 11:16 AM
moda_way's Avatar
I installed mine and other that a few scrapped knuckles and some frustration I like having the extra few hp. My goal though was to get to 200whp NA and I'm darn close. I'm a set of pullies away from it.
Old Jan 24, 2007 | 11:20 AM
joerockt's Avatar
Just dial 1911
My Comptech gasket still sits in its box
Old Jan 24, 2007 | 12:01 PM
moda_way's Avatar
It took a week of being totally bored before I did the install. Honestly, it all comes down to 1 bolt that makes it a PITA. A cool side effect... seening the car without an IM. Kinda cool.
Con #2: Needing to buy Acura Coolant b/c you aren't going to do a full flush
Old Jan 24, 2007 | 12:48 PM
chuson's Avatar
T.DoT P.I.M.P. lol
I'm planning to get it when I have a chance to get a set of 06 TB + IM.
So what about Head Gasket? I heard it can increase the Engine Compression and make a few whp out of it. Any ideas?
Old Jan 24, 2007 | 12:55 PM
TSX2345's Avatar
A DiRTBAG decal on my
I found the install to be fairly easy. Probably because I have removed and installed the IM atleast a dozen times. I first installed the Hondata then the 06 IM and TB then the Power Rev Racing gasket on seperate occassions. I also helped Shaang do his install too
Old Jan 24, 2007 | 03:17 PM
KapVu's Avatar
New to Modding Cars
what is PITA?
Old Jan 24, 2007 | 04:08 PM
gsclifton's Avatar
ABP TSX
Originally Posted by KapVu
what is PITA?
1) Acronym for Pain In The Ass, a major annoyance.
2) Flat bread of Mediterranean origin, eaten as is or filled with small pieces of roasted meat, veggies, condiments, etc.
Old Jan 24, 2007 | 04:16 PM
KapVu's Avatar
New to Modding Cars
^^hahaha i love the second definition.
Old Jan 24, 2007 | 04:28 PM
joerockt's Avatar
Just dial 1911
Old Jan 24, 2007 | 06:01 PM
xizor's Avatar
Bye TSX, hello domestic?
the install really is a PITA if you've never removed your manifold before, I wouldn't suggest doing it unless you're taking off the manifold for another installation at the same time.
the powerrev gasket is easier however, i believe no coolant flush is required
Old Jan 24, 2007 | 06:29 PM
TSX2345's Avatar
Correct, for the Pwer Rev gasket no draining of coolant is required
Old Jan 25, 2007 | 06:24 AM
moda_way's Avatar
What, no funny picture?
'01White3.2CL
Jun 30, 2007 10:21 PM
whatwasthat
Apr 20, 2006 01:01 AM
TypeSAddict
Dec 3, 2001 08:28 PM
