Camber Kit HELP - Ingalls Install
ABP TSX
Ok, my car is at the dealer right now getting the alignment done after installing a Pro-Kit (2 weeks ago)
They (dealership technician and service advisor) are saying I need a camber kit for the rear. The thing is, I HAVE an Ingalls kit installed on the rear now. They do not know how to adjust it.
Two links were replaced on each side using the kit. Which link adjusts the camber? The tech said (over the phone) he got the toe right on but the camber on one side is 3 degrees off and the other is 3+ degrees off. He said he tried to adjust it, but it do not have an adjustment for camber. WTF, I thought if you did aligments you could make the adjustments.
Pls post information if you know how to adjust the kit.
Why is the car at the dealership? Becuase no other alignment shop had the software for the TSX in the Dallas area. I called 4 places before selling out to the dealership.
EDIT
Called Ingalls directly and they are faxing over some instructions on how to adjust the kit to the dealership. It is a combination of of turning both replacements links to get the camber first, then you adjust toe. Hopefully, with the instructions, the dealership technician can figure it you.
Ingalls Camber Kit Instructions
EDIT
cycdaniel
12-17-2019 10:58 AM
nuldabz
09-03-2015 05:49 PM
2003, acura, acurazine, bc, camber, cl, ingalls, install, installing, instructions, kit, sitetsxclubcom, tl, tsx
