CAI filter change
Top notch 6MT
Originally Posted by GIBSON6594
The same way you put it on the first time
How often should the CAI filter be changed? (same as a regular air filter?)
Would SRI be easier for replacing the filter?
Originally Posted by JTso
How many miles did you put on the filter? It usually only needs to be cleaned and re-oiled.
My Garage
Its not so bad, just take the front driver wheel off, and a few clamps from the wheel well. loosen the clamp holding the filter on the tube and remove, repeat in reverse for re-install.
SRI is much easier for cleaning
The filter is reusable
Top notch 6MT
Originally Posted by 05_TSX_GP
Now that might have just swayed me towards SRI mode a bit more...
Faster, please.
I didn't istall it myself. It's been about 6 months/15,000 miles, and this will be the first cleaning. No I didn't read the manual because I don't know how to read. I actually do know the whole cleaning/re-oiling process so I don't know why I said "change" it in my first post. Do I definitely have to remove the wheel or can I reach it if I turn the wheel all the way to the left? Do the clips that hold the liner in place just pop out or unscrew?
Top notch 6MT
Faster, please.
There's nothing from Injen that tells how to access the filter. I read somewhere else on here that there are no instructions on their website. So, do I really have to remove the wheel?
I don't think you can get to it without removing the wheel but then again I've never tried. Thinking about it, I doubt it. You wouldn't be able to pull back the black plastic far enough to access it. Besides I think the filter is best cleaned on its own as there are I think two steps to cleaning it. No way you can do that with it still attached.
No need to remove the wheel to get to the filter. Just turn the wheel to the left, remove some clips and bolts to the wheel liner, then peel back the liner to expose the filter.
There you go. But can you properly clean the filter while its still on the car is the question.
EDIT: Your only asking how to remove it, not clean it
Faster, please.
You can get it out pretty easily without removing the wheel. Turn the wheel all the way to the left, pop off 2 clips (using 2 flathead screwdrivers worked), and 2 bolts with a 10mm ratchet. Peel back the liner and the filter's right there. Mine doesn't even look that dirty, but since I have it out I'll clean and oil it.
Top notch 6MT
Top notch 6MT
Originally Posted by say what?
how does one go about cleaning/oiling the air filter after removing it???..
Top notch 6MT
Here's some interesting info on the K&N cleaning instructions noted by JTso above:
"12. PERFORMANCE HINTS
1) Service every 50,000 -100,000 miles on street driven applications.
2) Service often in off-road or heavy dust conditions or when air filter reaches 18" of restrictions.
3) Let the dirt "build-up" work for you; it will not hurt the performance and actually help filter the air."
In otherwords, 6 mos/15,000 miles is still way too soon to clean it.
I've used K&N cone filters in 3 of my prior cars. All of the filters stayed relatively clean and I stuck to the above recommendations w/o any noticeable filtering or performance issues.
