brake disc size
brake disc size
Hello all...a call for help from across the pond ...now I'm after some rotor upgrades and have a UK Accord Type-S...I was wondering if any of you have any TSX rotors lying around so that you can give me the dimensions, both front and rear so I can check with my car?...pics and dimensions or indeed a link to online catalogues would be useful..thanks all hope you can help!
I have found out that the caliper is a different design, but hoping the discs are the same.
You can look at Brembo's website as well. They have a great dimensions page.
Acura has the dimensions at:
Front:
311mm x 70mm and 8.346kg
Rear:
293mm x 53mm and 3.742kg
thank you modaway...i guess i need to source different rotors....seems like there are differences with the brakes afterall.......The brakes on the accord have always been good, but i have seen a lot of TSX owners complaining about their brakes....
Anyway who are db rotors?
Again, check out Brembo. I know they have applications for JDM/EDM Accords.
Worst cast, just do the big brake kit from them which will give you a total brake package. You'll just need to increase your wheel size to an 18" to fit them.
SidhuSaaB
05-30-2020 12:40 AM
lanechanger
10-13-2015 10:56 AM
