audio help
Old May 9, 2014 | 01:59 PM
TSXer1's Avatar
audio help
Im installing a sealed box with 2 12" subs and amp in my 05 TSX auto. I want to run it from the factory radio assy. Can anyone give me some tips and advice on how to do a quick clean and easy install and tell me what all materials I will need.
Old May 12, 2014 | 03:46 AM
Districk81's Avatar
4th Gear
Damn no responses... Does anyone one have any information b/c im trying to do the same thing and need to know the best way and what all I'll need
Old May 25, 2014 | 03:01 PM
brad757's Avatar
7th Gear
Ive looked into that a little bit you need to go to the audio store and get a hi/ low converter because the amp needs to have the signal. The wires going to the speakers contain the signal along with power in order to work the speakers. So you need to run the speaker wires through the hi low converter and then run the left and right RCA's coming out of the converter to the amp. Only thing is the rear deck speakers in the TSX already have a pre amp so I would look into that a bit more but I think you should be ok. The converters are pretty inexpensive too!
Old May 29, 2014 | 12:56 PM
hypocalypto's Avatar
5th Gear
I picked up a sound processor from crutch field which did the trick. I only used a mono amp with a sub though
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
ValdezQ26
Oct 1, 2015 04:48 PM
navtool.com
Sep 25, 2015 05:15 PM
