Amuse Exhaust
Amuse Exhaust
Does anybody have this type of Amuse Exhaust on their TSX? If so does it fit theCL9 USDM.
http://www.japanparts.com/images/Ima...p?base=1&no=44
I want really want the feels exhaust manifold for the CL9. I just hope that it fits the USDM CL9 unlike the Mugen manifold where you have to slam in part of the sub frame
http://www.hondatwincam.co.jp/info/p...07-05-001.html
Driver/Detailer
Originally Posted by mav3556
Flange is the hook on the side right?
Anyways, the bolting pattern and the sensor hole seem look correct.
Boost Junky
thats a really bad example but I hope you get the idea
Boost Junky
my pathetic picture didnt come out right lemme try again lol
<O> and it will have a screw hole in the v parts connect the flanges together from the other piping
The flange in the picture looks the same as the USDM headers. So it should fit the USDM cat converter.
^ was about to say the same.
The EuroR has a different cat, but the CL9 in japan has the same cat hence the design difference in the CL9 version of the header.
Originally Posted by lito
I don't think I seen anybody outside of Japan with the Amuse exhaust. You'll probly need a JDM cat to fit it on our TSX.
Same 3-bolts rear flange
http://www.kingmotorsports.com/image...medium/558.jpg
I think after looking at pictures at the bolting patterns on the Feels/Maximworks exhaust manifold will work.
I just need a closer look at the bolting pattern for the amuse exhaust.
Amuse exhaust will work fine - there's no difference between CL7 and CL9 CAT exhaust-end flange, the only difference is at the manifold end.
And the same CL9 CAT is used the world over, irrespective of whether it's a TSX or an Accord branded model.
PJS, do you have this Amuse exhaust(dual tip euro)?
I'm already planning to get the exhaust manifold. I really looking for more mid-range torque and thats the reason I chose the Amuse dual tip exhaust because it's only light weight and it doesn't take away power from the mid-range torque curve.
joflewbyu2
10-08-2015 11:16 AM
