06 compared to 04
06 compared to 04
he 06 TSX has the following improvements:
Increased intake flow:
* Intake valve + 1 mm oversize
* Intake cam High lift lobe with 0.9 mm more lift and 12 degrees more duration
* Throttle body increased from 60-64mm
* Radius on some intake pipes increased from 70-80mm
Increased exhaust flow
* Exhaust Head pipe increased from 60-65mm
* Higher flow catalytic converter
* Main (single) exhaust pipe increased from 54-57mm
* Rear (twin) pipes increased in diameter from 42.5 to 45mm
Block improvements:
* Additional air passages in crankcase for reduced pumping losses
Other
* Stronger connecting rods
* New crankshaft with more counterbalance weight
* Revised pistons with more valve-piston clearance
thats from the hondata site. The 04 with reflash,headers,and CAI is th same as the 06 with just the reflash
Block improvements:
Other
mlody
12-04-2019 02:11 PM
Medinak12
09-23-2015 07:11 PM
