Is your 'outdoor temperature gauge accurate?
Got my TSX AT / non-Navi about a month ago. I love this car, coming from an EL 1.7 (Acura's version of a Civic in Canada) and haven't really had any problems.
I do find that the outdoor temperature gauge is not reading accurately and therefore, in my opinion is causing the climate control to work extra hard.
The radio will say it's 22c / 72f yet my gauge says 24c / 75f. I'm sure the A/C is making it much colder inside the car than the temperature I set it at.
Has anyone else had this problem?
The guage on your radio is the temperature you want your cabin to be. The temperature guage on your dashboard shows outside temperature; seperate from inside temperature.
My Garage
The outside gauge has nothing to do with how hard the CC works. there are sensors (one to the right and behind the steering wheel, and one near the front windsheild) that are used in conjunction to determine proper temp settings. The sensor for the outside temp is on the bumper.
Originally Posted by GIBSON6594
The outside temp guage has been known to be a few degrees off. See post 6 here to adjust it...https://acurazine.com/forums/showthr...t=temp+degrees
don't mind me, I'm just increasing my postcount.
My Garage
Originally Posted by jlukja
Yeah, what ^^^^ said.
don't mind me, I'm just increasing my postcount.![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Originally Posted by CGTSX2004
![No No](https://acurazine.com/forums/images/smilies/nono.gif)
You'll earn your posts like everyone else...
![Chuckle](https://acurazine.com/forums/images/smilies/chuckle.gif)
I'm the Firestarter
Also, you don't know where the readings are taken that are reported on the radio. Lastly, the temperature reading will not be accurate until you drive around a bit. When your car is standing still there are hot and cold spots behind the bumper (where the sensor is located). You have to drive a bit for it to pick up ambient temperature.
Is that better Belzebutt?
![Punch](https://acurazine.com/forums/images/smilies/punch.gif)
Needs more Lemon Pledge
I am sure mine was broken yesterday, as it said 114!!
What temp does Acura paint melt??
I notice the same thing on my 05 TSX too. The outside temp gauge is always a 2 degrees off what the radio annoucer says. However, my previous car, a 99 Passat, was always right on. I do remember reading something in the owner's manual on how to calibrate our outside temp gauge. Am I hallucinating?
afax226
afax226
Looking at the '15 TLX
Outside Air Temperature Display Adjustment
Courtesy page 22-228 of the 2004 TSX Service Manual:
Temperature can be adjusted +/- 3 degrees:
1. Turn ignition switch ON (II).
2. Press and hold the reset select button for 10 seconds. While you continue to hold the button, the display will scroll through temperature settings from +3 to -3 as shown:
0. 1.2.3. -3. -2. -1 (repeat back to 0)
When the desired correction value appears on the display, release the button, and the recalibrated outside air temperature will be displayed. Each time a desired correction value is entered, it replaces the previous value.
NOTE:
To recalibrate the display to the true temperature, remove the outside air temperature sensor but leave it connected. Submerge the sensor and a thermometer in a container of ice water. Select the calbiration mode as described above and recalibrate the display to the true temperature.
NOTE:
Is that better Belzebutt?![Punch](https://acurazine.com/forums/images/smilies/punch.gif)
In any case, both Intrepids I've owned were on the money every time.
That did the trick. The gauge is reading the proper temperature, most of the time
Actually, I do know where the readings are taken. Each of the 2 stations I listen to announce the place of the reading, for example, at Dorval airport it is now 27c.
it sucks because it doesnt account for humidity or wind chill.....like recently, the temp reads 31 degrees, yet its like 45 with humidity.
not a good feature and id prefer nothing at all.
My Garage
Jeez, what do you do to your lawnmower if it misses a blade of grass?
You'd rather have no outside temp guage than one that is 2-3 degrees off?
besides, i know the approx. temperature anyway (winter = cold...summer = hot)....or the radio says the accurate temp every few minutes....
Top notch 6MT
yeah...id rather have nothing than something that doesnt work properly.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
To answer the thread's question: my temp. gauge seems to be accurate within 1 to 2 degree (Celcius). Good enough for me
Top notch 6MT
CD player has never given problems...only once when i tried to play a really scratched up tupac cd; the player wouldnt accept it. does your give problems?
![pofl](https://acurazine.com/forums/images/smilies/pofl.gif)
I assume you never play CD in your car because you stay on the radio to catch the temp. report
![Ninja](https://acurazine.com/forums/images/smilies/ninja.gif)
My CD player is fine, even CD-RWs that some have said don't play on theirs
My Garage
I mean, its off by 2-3 degrees, its not like you can really feel the difference
I guess everyone really is different
What do you do that requires you to have the exact tempature to the degree?
My Garage
same goes for speedometers, tachs, oil temp, etc, etc, etc....whats the diff? ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
To me, if the outside temp is 2 degrees hotter/colder nothing is really going to happen that will change my life.
I know what your saying, but it seems a bit extreme to rather not have it because its off by 2 degrees...its a minor thing. I mean my cell phone does'nt get service ALL the time, but i don't throw out my cell phone.
Top notch 6MT
neuronbob
23
07-16-2019 10:48 AM
