You guys like the Steering wheel for the TL instead of the TSX's?
I got the TL for a loaner car and I kinda liked the TL's steering wheel better than the TSX's.
Never drove the TL but I don't like the steering wheel on the TSX. I think it's way too big and I wish the spokes that attaches the wheel to the center could be higher up. When I rest my arm on the door rest my hand hits the wheel right where the spokes attaches so I can't get a grip on it unless i lift my hand up or drop my hand lower.
Originally Posted by CGTSX2004
Actually, if there's any steering wheel that I want, I want the one in the RDX.
I much prefer the TSX wheel to the TL - it was actually one of the reasons why I chose the TSX.
IMO, a 3-spoke wheel is noticeably sportier because you have more freedom to slide your hands while cornering because they are less restricted between 3 and 9, compared to a 4-spoke where your hands are blocked off from sliding at all by the spokes.
the 06 TSX wheel should be a direct swap to the 04-05 TSX. Take out the airbag unit, unscrew whatever u need to. The only thing is probably the radio control part, anybody know how that part works?
KC
KC
^^ yeah, that TL-S one is very nice. i wished the acura steering wheel was a little smaller for more sporty feel.
Originally Posted by bibby
I like the TSX steering wheels better. It's perfect size. The only issue with my 05 is that it can be thicker like VW/Audi thick. Then it would be perfect!
Originally Posted by gfd1182
is it possible to swap the 04' tsx steering wheel with the 06" ?
https://acurazine.com/forums/showthread.php?t=33495
Make a hole, coming thru!
The TL wheel does look less like the HFL and Info buttons weren't added on. I like that about it.
I swapped an 06 wheel into my 04 and couldn't be happier with it. It's a definite improvement. I kept my original airbag and steering wheel controls and popped them into the 06 wheel.
As for a TL OEM wheel, you'd need to determine three things:
1) Would it bolt up to our hub (most likely, I think Honda designs are fairly universal)
2) Would our airbag fit (just by looking at it, no)
2a. Would a TL airbag properly connect to our wiring harness and keep SRS functional?
3) Would the button modules fit (no)
3a. Would the TL button modules properly connect to our wiring harness?
So... it could be doable, but it would be expensive to get a whole new set of parts.
Maybe it's just me, but compared to the 06+ wheels, that 04 wheel looks spaghetti thin. Another notable difference (that might have been mentioned before) is the 06+ wheels have little bolsters at 10 and 2.
