XM Plug? (AUX installation)
I haven't yet bought a AUX adapter but I plan on it, and I removed the cubby in my 05 TSX (No Navi) and I tried to check if I had the slot to plug in the adapter (under the radio) and I already had something plugged into it, and I can't seem to figure out what it is and how to pull it out.
I have been told its the XM which I don't care bout because I never renewed the subscription. How do I unplug it because I keep pulling it but its not budging
Doesn't answer my questions, what's the plug and how do I remove it (the one under the Radio)
There is a small lock tab on the plug that must be depressed to allow removal - the plug cannot be removed without damage if the tab is not pressed.
The video suggests using a small mirror to examine the plug to find the tab release. I found the release tab by looking at the Isimple aux/Ipod adapter that I added - the Isimple plugs into the radio socket and the car cable is plugged into a socket on the Isimple. If you don't have the aux adapter yet, then the mirror is probably the best way to locate the lock tab. I can't give any hints on the location of the lock tab because it was several years ago when I did the installation.
(I have the exact same model 2005).
Attached is a picture of the connector from below. I can't spot the release tab in this picture. The white connector on the right is the one you are working with.
cycdaniel
12-17-2019 10:58 AM
