Wow I go in for yearly inspection and they wanted to get me for $1150
All I can say is I'm shocked.
I went in this morning to my local Acura dealership for my annual state and emission inspection. I checked everything the week before to make sure everything was at least minimum.
So their advisor comes over and says the rear pads are at minimum (I'll get to this at the end) and that the rotors are below the limit for resurfacing. Total cost $500 for new rotors and pads. The front ones were around half way worn out. The rotors are warped from the deposits which I know about. So they wanted to replace them as well as the rotors for $550. Also they try to push very hard their engine cleaning for $100.
All in all, the bottom line I asked them is do I pass inspection? He said yes. The front ones while have problems they do not need to be done now.
The rear ones, I will need to check the inner pad this afternoon or tomorrow. I went out in their recommendation and bought the new pad and rotors. Checking the pads, I think they are around 40% still good.
I understand that people need to make a living but WTF. I would expect that they just tell you this and say you have around another year before you need to take action on the front and a few more months on the rear.
I had put the Hawks and Brembos on the front but took them off because I didn't have enough time to break them in. That's going to be the project for tomorrow.
3G TL/2G MDX Owner
tech says stuff about your car, SA's job to sell you the work to be done. your SA makes it sound like it's imperative that the brakes be done NOW.
i have a pretty good rapport with my dealer, and while they tell me about the condition of the brakes and other wear items, they NEVER push the premature maintenance items on me. they tell me, your brakes are down about 40%, nothing major, but just so you're aware, you'll need new pads in the near future. they even go as far as showing me things on the car that i need to be aware of, but not critical. my PS pump is a little weepy, but nothing crazy. they showed me what was going on in the shop with the hood up. the tech gives me his 2 cents, my SA gives me a price and they both tell me what will happen should the part completely fail. that's it. no hard sells. they let me dictate how i want to proceed with said items.
not all dealers are out to get you.
the upside, you have resolved your pricey brake job yourself, despite your dealer trying to pry more money out of you.
I have to drive a good distance even though there is a local Acura dealership by my area. I have heard too many problems with the local one though both are owned by the same owner.
I do believe that anything under $100 and they dealer isn't paying for their workers. That's why they try to sell you I'm guessing at least $250 on any visit.
I think the SA knew I wasn't going to get anything done that's why they passed my inspection. The inner pads were a bit more worn but not to the point they would hit the wear indicator. I guess they figure if I have to bring it back, someone will lose another hour inspecting it again and not get paid for it. That's probably why they just pass you if you can't cause harm until days later.
And from their write-up on the receipt, the rear rotors would be below specs IF they were machined. They were fine for use but I replaced them. I don't know if they would fail me next year if they were below specs.
I kind of had a similar experience. Like 2 years ago they told me that my clutch needed to be replaced ASAP but I told them that I'll do it some other time. From that day on, clutch replacement stays on the paper work whenever I had a oil change done.
Currently, clutch still grabs strong. Well i'm sure the clutch probably needs to be replaced now since I've had the car for almost 9 years now. I do drive in San Francisco once in awhile and bay area traffic is crazy.
They should be ashamed for the people that know nothing about cars. But greed has no conscious.
Your Friendly Canadian
Received 1,485 Likes
Wait... So they want more than a thousand dollars to do brakes!?!? That's the most insane quote I've ever heard.
it's a car-drive it
the acura dealer I now use the majority of the time only recommends service. Most of the time it is things that are not necessary. Have not fallen for their overpriced add-on service. I miss my regular dealer in Pa. They never tried to sell me these ridiculous things.
Guess for them not selling enough cars they have to make it up some how, some way. Like un-needed recommended services, valve adjustment, etc..
nj2pa2nc (11-20-2013)
Valve adjustment is actually in the owner's manual, is it not? Around 110k miles.
TLDude876
12-28-2016 03:18 PM
Joseph Stansbury
34
12-04-2015 01:57 PM
asahrts
09-04-2015 05:55 PM
