Wow! Actually got dealer to replace rotors and pads!
Hey guys,
Just figured i'd report that i actually got the dealer to replace the pads and rotors without trying to machine them. They didn't even ask really... i report braking vibration and they just called me on the phone and said that they replaced them.
So i guess i'll be ok for another 20k miles until i have to replace them again. Which at that time i'll upgrade.
On a side note... i noticed my air pressure was a little low on one tire to the point where the stock tire was flatspotting. Thats the tire with a little leak and my replacements haven't come in from tirerack yet. I didn't do any highway driving, but since i was in a huge hurry, i didn't have time to put air in the tire. Do you think i did any damage to my suspension like that?
thanks
thanks
How many miles do you have on your tsx? I just hit 21,000.. and I just called my dealer friday gonna drop it off sunday night for the same issue. Hopefully I will get lucky but ain't gonna count on it. They will probably just resurface them..
Originally Posted by 6SpeedTA95
Why will you have to replace them again in 20k miles?
Originally Posted by Alin10123
Because word around here is that rotors warp around 15k on the car. I do a lot of highway driving and i drive more conservatively. That's why mine lasted almost 20k. But i've just got a feeling that in another 20k they will warp again.
My rotors warped around 15K. Granted, when I first got the car, I was driving aggressively but obviously these rotors aren't that great. I think I'll save myself the hassle and upgrade to Rotora's or Brembo's.
That pretty much bites ass...so I guess the word to the wise is as soon as the warranty is up and you have a rotor issue get some aftermarket rotors...
Are you sure they're warped? I can't imagine a street driven car generating enough heat to warp rotors.
Could be the pads are not properly bedded in. Read...
http://www.stoptech.com/tech_info/wp_bedintheory.shtml
You'd be surprised a thin rotor can warp easily even moderate braking generates tremendous heat
I tracked that car with stock brakes 3 times and never had a problem.
I'd wager 85% or more of the "warped rotors" we read about on this and other forums are simply uneven pad deposits caused by improper break-in.
Just my
I didn't find the rotors on my 04 TSX to be "thin."
Just my
Just my
Heck... i have no idea if they were actually warped. But there are tons here that complain of brake vibration all of the time. Yes, i did follow proper brake bedding in procedures when my car was brand new.
Enjoy!
Well, free rotor and brake pads and rotors are great if you don't have to get them replaced often, I've my front set replaced at 23k then 25k miles... now on third set of rotors and pads
I rather have brakes that just work well
but all in all, I honesly think it's the brake pads that's causing the wrapped rotors, vibration, squeaks...
On a side note... i noticed my air pressure was a little low on one tire to the point where the stock tire was flatspotting. Thats the tire with a little leak and my replacements haven't come in from tirerack yet. I didn't do any highway driving, but since i was in a huge hurry, i didn't have time to put air in the tire. Do you think i did any damage to my suspension like that? It was the front right tire and it was 5-10 PSI low.
thanks
thanks
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
