Will 2007 TSX exterior bumpers/headlights fit on a 2004?
I've searched without any luck. I love the look of the new TSX, and can't tell by just looking...
Will 2007 bumpers/skirts fit on a 2004?
Also, are the hood/fenders/headlights different?
Search in the performance parts section. This discussion has been "discussed" before.
Freebie, yes they will fit onto a 2004-5. They are a direct fit.
Headlights are different, fenders should be same, hood is different. 06-07 does not have hood trim.
headlights are the same, not different. stock ballast sizes are different for the hids, but that doesn't prevent them from being able to be swapped.
04/05 bumpers are interchangeable with 06/07 bumpers, just the lip kits are not, for obvious reasons.
Hoods are also interchangeable, just know that the difference between oem versions is the trim piece. But, if you wanted a carbon fiber hood for an 07 that was listed as fitting 04/05, then that works, that kind of thing.
acura_dipset_tl
01-01-2016 03:02 PM
EvilVirus
12-10-2015 07:38 PM
