where is the maintenance light?
thank you....by the way I dont own a tsx....yet .I dont have access to a manual and I was just curious but thanx for the pic even though I still cant see the light but if you say its there then its there.....
Originally posted by MIA305
......I still cant see the light but if you say its there then its there.....
You can't see it because it's not on. If you want to know exactly where it is: There's that central "circle" with the odometer numbers, right? And within that, the the portion that actually contains the numbers is this sort of bluish blackish illuminated "square"? And, right below that (attached to it), there's a very faintly illuminiated downward extension of that "square," making the whole thing into sort of a vertical rectangle? (The downward extension is hard to see, but you CAN see it if you look for it.)
Well, the thing you're looking for is in the extreme lower right corner of that rectangle.
Better make a note of this, because I'm not gonna do it again.
mada51589
05-03-2022 08:54 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
ahsm
09-09-2015 08:35 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
