Where can I find some 3000grip sand paper??
mmmmmm....
I tried Target, home depot, shucks and other few stores but couldn't find any!!? DO you guys know where I can find some?
mmmmmm....
I tried Home Depot, Target, Shucks, and few other stories but couldn't find any? Where can I find those sand paper from?
Grip sandpaper?! Don't know about that, but if you're looking for 3000 grit sandpaper, that's pretty fine stuff. Have you tried auto repair suppliers?
TSX4EVR
mmmmmm....
Originally Posted by excited
mmmmmm....
I've gotten 2000 at AutoZone before, you might see what they have.
That's the grit I use to hone my plane irons and chisels. Makes tool steel as smooth as a mirror.
mmmmmm....
Originally Posted by CJams
3000???? might as well just use toilet paper! If anything you would have to go to a body/paint shop.
BTW- whats it for?
BTW- whats it for?
https://acurazine.com/forums/showthread.php?t=26590
I found this method so I was going to try doing this!!~
Here's how I would do it:
First you need paper matches, a nick sander, touch up paint, clear coat paint (optional), blue masking tape, rubbing alcohol, 3000 grit wet sandpaper and sanding block, small bucket of water, swirl mark remover, and polish/glaze.
First clean the scratch with the rubbing alcohol. Put the blue masking tape around the scratch. Then make a few passes with the nick sander to clean any stuck on crap in the scratch. Wipe down the scratch with the rubbing alcohol again. Apply the paint with the back end of a paper matchstick. Don't brush it in, just kind of let it flow into the scratch. You'll need to build up layers, letting each one dry before you paint in the next one (at least 15 mins). Build up the paint so it's a little above surface level. Once the last coat of paint is dry (if you use clearcoat, it'll be the last coat), then wrap your 3000 grit sandpaper around your sanding block and dip it in water. Sand down the scratch to the surface level, keeping the sandpaper well wet. Once it's dry, use the Swirl mark remover. If that doesn't get rid of the sandpaper marks, you might have to use a Fine Cut Cleaner. Then polish. That's all ( ) there is to it.
mmmmmm....
3000 grit is basically like rough paper. i've used 2500 and thats pretty much all you can really use on paint.
you might want to just buy a thing of rubbing compound, some meguirs goo and buff it a lot , i would figure that wouuld probably be better than 3000 grit anyway.
SinCityTLX
20
10-19-2015 11:23 AM
