What oil filter you're using?
We all know that Honda/Acura have 2 oil filter made by 3 different company. The small one which is what our car calls for and the bigger one found on suv, S2000, and some other. The three company are Toyo Roki, Filtech, and Honeywell.
Based on what I've read, the best out of the three is toyo roki, then the filtech, then the honeywell. My surrounding dealer only carries the Filtech and honeywell. The filtech is starting to be hard to find.
I use the bigger of the two made by toyo roki if i can actually find it and the filtech. Honeywell .. lol hell no. it's fram. So what do you use?
Modding newbie
I use K&N's filter because it has a 1 inch nut on the back so I never have to worry about getting one of those stupid filter wrenches in there if it's stuck. Just put a socket on it and you're good to go
Used Mobil 1 filters for the first 4 years (2005 model), until my local Autozone decided they were so proud of them that they wanted $12.99 each. Now I use OEM Honda (Filtech I believe).
Almost Doctor
I spent so long trying to figure out which filter to use. After reading some independent tests, I decided on the Mobil1. And yeah, they cost $12.99 ea but she's worth it.
Someone stole "My Garage"
Bosch premium (#3323). Very high quality internals, inexpensive, and available many places. Its the one in the BLACK box with the BLACK filter can. Has their ultra-premium filter media and is built like a tank compared to a Fram/Quaker State/Motomaster/etc.
OEM is likely Fram. Fram is garbage.
Back a few years ago, there were Toyo-Roki brand OEM filters -- those were excellent filters. But that was then and this is now, when Honda/Acura uses Fram/Honeywell as their OEM and the quality isn't as good as it should be or once was.
mobil 1 end of discussion
and if you dont believe me on how big a difference there is in terms of quality between OEM and mobil 1, check this link. the pictures speak for themselves https://acurazine.com/forums/1g-rdx-2007-2012-147/oil-filter-honda-vs-mobil-1-a-682139/
I've heard this sentiment before: "Fram is garbage". I have no dog in this fight, but I'm curious what prompts this comment (and if anyone that makes it actually has any idea what they're talking about). I'm guessing there are "independents tests" out there that show how great or how crappy they are (it seems like you can always find a "test" to show that your opinion is the right one), so I'm reluctant to fall into that trap. I do remember that years ago, Consumer Reports did a pretty exhaustive test and Fram did quite well. Plus.... since I imagine Fram must sell like a gazillion filters every year, if they're so crappy, I wonder why the streets aren't littered with like tons of blown engines resulting from having their oil filtered by Fram.
there's numerous test out there that already deemed the Fram is garbage. I myself have used fram in the past on older vehicle. And never once have i missed my scheduled oil change. Out of all the time, I've found gasket still stuck on the engine with fram filters and none on Filtech/Toyo Roki OEM. .
Frankly for $5000+ for a new engine, I'll spend the extra few bucks or extra few minutes (researching) to find a filter that isn't prone to failure or poor filtration, instead of replacing my engine.
Yes Fram "works", but for the price you can get a Bosch 3323 or even OEM (non-Fram ones) for the same or cheaper, and they're proven to filter better.
Valvoline Synpower with Purolator Pureone Filter
smoothest oil i've ever used in the TSX
http://www.youtube.com/watch?v=oCBr4YfQNfk
i would NEVER use a fram which means i won't use current OEM honda filters
El Cunado
El Cunado
You haven't shown any proof that any filter is better than any filter; you've only given your opinion and shown a youtube video.
Here's a good read:
http://minimopar.knizefamily.net/oil.../opinions.html
http://minimopar.knizefamily.net/oilfilters/index.html
http://people.msoe.edu/~yoderw/oilfi...lterstudy.html
El Cunado
The you tube video is data. The opinon is an interpretation of the data. Which is like every hard fact that you will read/see. I can give all the data you want, but it still needs to be interpreted and a conclusion is drawn from it.
Here's a good read:
http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilterstudy.html
Here's a good read:
"I personally do not use this filter, but the design didn't have enough bad qualities to cause me to tell others to avoid it."
"In my opinion, the only real drawback to this filter is that it is capped on each end with cardboard instead of metal. "
These websites, while containing good information, don't say that Fram filters should be avoided or provide inadequate performance. I won't avoid looking for a new filter based on this, but it doesn't cause me any real concern about the filters I've used for years without having issues.
Time to get a life guys. How about we agree to respect each other's opinions and move on to something really important, like..... "The benefits of using summer air in your tires during..... the summer".
If you guys use the Honda OEM filter, make sure you buy the one with the following part number:
15400-PLM-A01 (*made by Filtec, not the garbage by fram*)
The one made by Fram has this part number:
15400-PLM-A02
Post #61 shows the difference between the OEM Filtech filter vs Fram crap:
https://acurazine.com/forums/showthr...=682139&page=2
15400-PLM-A02
Purolator made a "INTERESTING" video on why you should not use a oil filter with paper end caps (ie., FRAM, Honda OEM Filter - A02):
http://www.purolatorautofilters.net/...es/videos.aspx
Proud Acura Owner
15400-PLM-A02
15400-PLM-A02
the dealer always uses the blue metal Honda one.. that's good right?
