What kind of jack do you use?
TSX4EVR
I did a search on this and did not find anything. For those who change their own wheels from winter to summer, what kind of jack do you use? Will just the ordinary bottle jack work fine or do you need something special?
I want something over and above the jack that comes with the TSX.
Excited
Excited
Received 3,860 Likes
A simple search returned this about 2/3's the way down the first page
https://acurazine.com/forums/showthr...highlight=jack
However rather than just posting that and leaving it at that here is the jack that I use and love.
http://www.sears.com/sr/javasr/produ...id=00950240000
It is definitly worth what I paid for it. Makes raising my car up everytime I change my suspension height or change wheels (which I do frequently) very easy.
TSX4EVR
Thanks, I guess I did not use the right key words.
After golf is over on TV I will head over to Cdn Tire and pick up one of these two jacks:
http://www.canadiantire.ca/assortmen...=1144012954724
http://www.canadiantire.ca/assortmen...=1144013145713
Excited
Excited
I would go with the second one you posted. it you have lowerd your car or plan to at all you will have trouble getting it under your car at all.
No-navi, yo
I have a Craftsman 4-and-half-ton bottle jack because I don't have a place to store a floor jack. The bottle jack lift the frontal wheels with the minimum clearance off the ground. It allows me change engine oil and such, but I think floor jack would be a lot more useful.
Excited
Excited
There is a plastic socket that just decided to give up.
I was lucky because my wheel was still on (I put wood blocks anyway).
I filed a complaint. I guess Honda did not care because it is not supposed to be used for regular wheels swap.
No-navi, yo
how do you get the bottle jack under the car man.
Originally Posted by jlukja
This is the one I bought a couple of weeks ago.
http://www.sears.com/sr/javasr/produ...Lift+Equipment
TSX4EVR
Well I went cheap for a change and got a floor jack for 22.50 Cdn on sale. I believe that it is this one.
http://www.canadiantire.ca/assortmen...=1144028613657
I expect only to use it twice a year, up and down a total of eight times, which is 80 times over 10 years, so I think it will be up for the task.
I changed my winter wheels over to the OEM wheels today. I had an impact wrench to help get the winter wheels nuts off but did not have the right socket to take put the OEM nuts on so used the tire wrench that came with the car. I know how to tighten it and hope that they are all on tight enough.
Here's how my RBP TSX looks now:
Excited
Excited
Where are the jack points on this car?
On my old BMW, I would lift by the front crossframe or the rear differential. There were re-inforced pads on the 4 corners to put the stands under.
How are you guys lifting the TSX? Where do you put the stands?
They don't take up that much space man. Put it in your bedroom or something if you have to. You'll be able to sleep easier looking at it and knowing that if you suddenly need to lift your car it'll be easy
factory jacks are stupid.
Someone stole "My Garage"
Hey they are good for what they are designed for: taking up a tiny amount of space and working well enough to pop a spare tire on if you have to. Anything more than that and you need heavier metal though for sure.
Yes, I still use a jackstand on the corner I'm working on, although the weight is still usually mostly on the jack. If it were to fail, the axle stand would catch the car no problem and I'd be safe.
For working on the brakes or inspecting stuff in the wheelwell, I'd strictly use the axle stand and never trust any jack (common sense).
6th Gear
For those of you who use floor jacks, Eastwood Co. makes an adapter that fits the OEM TSX stock lift point perfectly. They also have an adapter that has a thick rubber pad which will not mar the underside if you chose to use the center front lift point. I have both and they work well.
She said: it's GINORMOUS!
my friend picked up a Blue Point race jack from snap-on, which i used when i changed my fog bulbs...man that thing is light as hell. makes my craftsman look feel like a friggin brick!
Originally Posted by dP-
Where is the jack point on the rear? I did each tire individually as I couldn't find a point close enough to the bumper (and could actually lever the jack)
where is my garage?!
1 Post
hate to resurrect this thread, but i'm just wondering if those of you who bought that low-profile jack from sears have suffered any issues with it? i was looking to get one but it received such horrible reviews. i don't know if i should go to the local autozone, napa, or pep boys to see if there are some other options. thanks.
I didn't realize it got those terrible reviews until after I bought it. So far I haven't had any problems with it. It may be a case of happy customers not posting and unhappy customers finding a way to vent. However, if you can find something comparable for a similar price I would probably get that just based on the reviews alone.
1 Post
good point. the likelihood of angry owners posting is probably greater than those who are happy.
i'll have to look around locally to see if there are any places that sell a low-profile jack w/ the specs everyone is mentioning (17" lift). thanks for the suggestion.
I bought this jack a few years back:
http://www.pelicanparts.com/catalog/...yd1_pg2.htm#29
It has been worth every penny spent!
1 Post
haha. better be nice for over $300 bucks.
but i can't really spend that much on it. just need something that's somewhat reliable and easily stored in a closet. maybe i'll pick up one of those when i actually have a house/garage.
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
the one I bought. when I went to sears they had that one, and a low profile one for 180. so I took the cheap route. it fit nicely under my 2.5" lowered civic. plus it comes in a convient carrying case if you need to move it around.
Although you wouldn't be able to store it in your closet, I absolutely love my DK20, even a couple of my friends bought them after they checked out mine. Best damn jack made...no doubt! I only paid $220 for mine though
I also have a couple of friends that use the Harbor Freight aluminum jack, something to check out and it's light.
Harbor Freight Jack
Harbor Freight Jack
some of these jacks have a max range of 14-3/4" or 15". That doesn't seem to be enough, in my experience, to lift the car using the front or rear jacking point and have the tires clear the ground. Unless you use some kind of spacer.
navtool.com
31
11-16-2015 08:30 PM
SUPRMN84
10-07-2015 09:46 PM
navtool.com
09-25-2015 05:15 PM
