what does vtec actually sound and feel like?
I have a stock '04 engine and I've been trying to hear any change in exhaust note or feel for a power surge around 6000 rpm but so far I haven't noticed anything. VTEC is one of those things Honda owners put on a pedestal so I was just wondering what the big fuss is about =P
Originally Posted by OoKrnBoi0331oO
kinda like freedom for me, it doesnt feel like there's any restriction...kind of like all of a sudden you're gliding.
^^no that would be crank....as for VTEC...it kind of whines a little bit at 6k rpm and pulls a little harder
Let me help you!
Did you get hondata? If so, the RPM is lowered to 4.3k-ish and it's set so that the vtec change-over isn't noticeable.
Otherwise, at 6k, the RPM's should shoot up fast, the engine will sound louder, and you'll feel a bit of a stronger pull. If vtec isn't engaging, your oil pressure might not be high enough.
well i bought my car used so i am not sure how i can figure out if it's had a reflash... i'm just assuming it hasn't...
it doesn't help that the window between 6000rpm and upshifting is so small...
haha rocketships. c'mon, the eariler vtec motors had a distinct profile change when it switched over, just like suddenly the motor turns into something totally different. the new ivtec with vtc is designed for smoothness, so it the average non-informed driver does feel more power, but he/she probaly wouldn't know exactly when. you can try to search on youtube for a tsx or rsx or newer civic si with exhaust/intake on a dyno or something. you should be able to tell when it switches over.
ha... nice found something that'll give me a better idea of what to look for next time...
also, i've been trying to hear it in 1st gear... vtec in 2nd gear is too fast for me
http://youtube.com/watch?v=GfToIocVpyQ
2006 ASM tsx
its kinda like..
vrooooom
then it goes vrrRRRRRR000000000000000000000MMMM!(second you hit 6k...)
get an intake of any brand. you'll hear the dif.
or.. lol back in the day for kicks. i took the the lid off the air filter.
you can hear it that way too... but i wouldn't recommend it. what if ur filter flies out. lol.
vrooooom
Sweet!
I had been wondering the same thing. :-D I think I notice it best when mashing it after crusing at around 40 MPH. I never notice it on the freeway. I wish I had another car to compare! Oh well.
Stock '04 as well.
I want to upgrade the intake, but I can't justify the $200+ just yet....and I'm too lazy to switch it over whenever I take the car in for service (still under warranty).
Stock '04 as well.
Trolling Canuckistan
Vtec has been mellow out over the years mostly because a lot of the people who can afford theses cars new didn't like the snappy transition it used to have. If you really want to experience Vtec, get your hands on a 5th gen Prelude or a Integra GSR. Those old Vtec engines like the B16, B18 and my personal favorite the H22 had a lot more snap when the Vtec engages the more aggressive cam profile.
In Boston we use to words to describe both the sound and feel of Vtec
Wicked Pissa!!!
Wicked Pissa!!!
Originally Posted by vthree
its kinda like..
vrooooom
vrooooom
tape that bitch down!
2006 ASM tsx
Stock '04 as well.
Stock '04 as well.
i got my first k&n cold air intake with everything. for only $65 shipped!!!
also people sell theirs quite a few times in the BM
Check out the Hondata Reflash review on Temple of VTEC.
http://www.vtec.net/articles/view-ar...icle_id=339233
At the bottom of that page are a couple of video clips (with sound) of the dyno runs. Listen for the change in the tone of the engine at higher RPMS, it gets a little more raspy and aggressive sounding. That transition is the vtec crossover.
Make a hole, coming thru!
When I got my vehicle, I did a couple of careful 1st 2nd and 3rd gear accelerations up to redline. Well, the first couple of times, I sped from 6000 to well into redline and I think I encountered that limiter thing. That, to me, is what vtec does.
My impression of Vtec, at a point when other engines are running out of increase of RPMs, this engine gets a sort of second wind and goes right past redline without a complaint.
VTEC (which stands for Variable Valve Timing and Lift Electronic Control) is an electronic and mechanical system in some Honda engines that allows the engine to effectively have multiple camshafts. As the engine moves into different rpm ranges, the engine's computer can activate alternate lobes on the camshaft and change the cams timing. In this way, the engine gets the best features of lowspeed and highspeed camshafts in the same engine.
And as for the system its self making a sound, I think it has more to do with the sound of the engine/pitch of the exhaust/intake as a result of the change in the cam timing , and not as a result of the something in the system its self.
honestly, my old non-vtec sohc f22 in my accord sounds wayyyy better than the vtec in my 97 cl. I remember when I would floor that sucker, and it would literally scream.
but yeah, vtak is overrated.
Driver/Detailer
CL9 ABP
They explained it already its the cams going to a higher lobe so when your flooring it you hear the steady acceleration and then you hear a higher pitch towards the end thats vtec engaging.
http://www.vtec.net/articles/view-ar...icle_id=214692
http://video.vtec.net/04/tsx/aemtsx.wmv
you hear it around the end of the gearing
for 04.05 only get vtec 6800-7200
with hondata you get
http://video.vtec.net/tsx/tovtsx_hondata_dyno.wmv
I definitely can tell the difference on my 2006 tl, after I put the short ram cone intake I can really tell, ive had sooo many people ask me if I have turbo, nopee just a monster v-tec! She sucks hard!
rockyboy
08-04-2024 10:35 AM
marcelft
07-10-2018 06:17 PM
