Voice command: working or not working?
Originally Posted by dP-
I'm a fellow Torontonian, and have been having problems with my navigation as well. I haven't played too much with the voice commands, more with the touch screen. I have posted a thread about the problems I've had here:
https://acurazine.com/forums/showthread.php?t=5258
I hope since we have the new Canadian navigation system (new in 2005), that we're not getting one that wasn't fully tested. Doesn't make sense, since all they should have done was make a new CD for the US version. Let me check out my voice commands tonight to make sure I don't have a lemon navigation...
The agent said it should be controlled by turning on the headlights, but this doesn't work either. We are going to get it fixed next week at the same time.
Ya... check the voice command out and should get it fixed ASAP. I found it very, very useful (when it works... hahaha) and you can even change radio station by saying 'radio FM 102.1'!!!! So no more dangerous driving because you have to look at the console to make changes.
Originally Posted by jpooncanada
I personally don't think it's the mic... because if that's the problem, it won't even pick up our voice. I think it's more like the programming of the system or the voice recognition configuration or setup.
The agent called this morning and told me to bring the car in next Monday and they will have to diagnose what's wrong and fix it. They are keeping it til hopefully the end of Tuesday.
Maybe it's configured to do French recognition?!
I am lurking on this thread even though I don't have Nav coz I've used voice rec. software way back in early part of 90's on IBM OS/2 Warp. The voice rec. on that desktop OS worked pretty well and does not need user training. I am assuming the voice rec. on TSX Nav does not need user training as well?
Originally Posted by 05_TSX_GP
I thought he already found out which part was faulty and placing an order already...
hahahaha, if that's the case... can I get a Chinese one? Cantonese in specific pleeeeeeeeze... hehehe
It doesn't need training for sure. We just jumped into the demo car and both of us tried and it works like miracle!!!!
oh.. as a note.... I tried 'Find nearest chinese restaurant' which I find the most difficult command to pronounce... and it works... hehehe
That doesn't seem like a real tongue twister!?! Maybe you can use a Chinglish version voice rec. indeed
I think the software is Via Voice (or some algorithm based on that engine). So its quite possible that you could have some switch for French (or different DVD)?
Thank goodness for that
Last I check English and French are the only two official languages in
Glad to let me know that English and French are the only official languages. English is already hard for me, French is deemed as impossible for me. Don't give me anything more than that.
Um... you do know that you can "calibrate/adjust" the sensitivity of the microphone? When i stepped into the tsx nav, i could not for the life of me get it to adjust to 70 degrees. But i started fiddling around with the mic settings.
You go into the navigation "setup". The geeky screen. I think you have to hold down cancel, and the two buttons to the left of it for 5 seconds. When that screen comes up goto "functional setup" then hit "mic volume" (not sure of the exact phrase, but there's only one choice for microphone.
That's when the screen for mic adjustment will come up. hit the "talk" button on the steering wheel and let go.
Now here's the tricky part, the louder you talk at this point, the louder the Nav system assumes you normally talk. So it will reduce sensitivity to the mic and will be harder for it to understand commands.
What i did was spoke as quietly as possible. Giving the calibration only 3 bars.
After that... every command i spoke with was understood perfectly.
Give that a shot, and let me know how it goes.
Another thing is that it only has 10% problem getting my 'air conditioner' command but all the rest fail. So do you think it's the mic having problem?
hm... interesting... do you know if I do it wrong, will it cause problem to my NAVI? I don't want to risk screwing it more than what it is now... Since mine is a lease will it be possible that if they know that I played with its setup, will they charge me for getting it fixed?
I'm pretty sure you can't mess it up
I'm also pretty sure if you do mess it up, you can always just unplug the battery for a few minutes and it should reset itself back to default.
I think it's the Mic sensitivity problem. It's probably just set too non-sensitive. Plus everybody's voice is different. So it just needs to be adjusted.
And I do not recommend unplugging the battery as a "reset to default", no such need whatsoever; why mess around with other parts of the car when it's just the Nav components or just a setup/config issue...
I am sure you can't break anything by using the set up screens of the system. They can't possibly charge you for anything - you are just adjusting the voice rec. system as you should; like adjusting your seat using the seat buttons... can they charge you if the button falls off when you press on it like you should?!
I was just trying to make "jpoon" feel better about it.
I know that there's no need to unplug the battery to reset everything since this is a relatively simple adjustment.
than she already seems to be
You got these effects to stay after you turned the car off and back on again?
I realize that... but I am afraid if she had really unplugged the battery, the need to reset radio system (security code) and possibly other things may make her even more
So... anyone here try to adjust the sensitivity on their microphones yet? I'm telling you, it works...
jpoon, have you tried it yet?
Hi all,
I want to find out what's your experience with Voice Command. Has anyone use it, try it, and anyone get it working 100%???? We tried really hard and no matter what we say, the answer is always 'pardon', 'can you repeat', or 'air conditioner' (even from a 'Find nearest chinese restaurant' command?!?!).
Jac
Jac
What?? My navi doesn't say "pardon" or "can you repeat?"... Is it a newer version thing?
Day 1 with Service on Voice Command unit
Brought the car to dealer yesterday morning and I'm guessing that they have put in a new unit into my car... all settings gone... all previous addresses gone... GONE!!!!! sigh.....
They said they think it's the mic receiver problem, so they've ordered the part in, but they are not sure when they will get it... 2 days up to 2 weeks!!!! sigh.....
Scratch on door switch panel is not fixed either... ordered... waiting... sigh....
Found a couple of scratch marks on the passenger side when picking up the car yesterday... going to try use some cleaner to see if it's dirt mark or real scratch mark... if it's real scratch mark... they are dead meat!!!!!
lol... did you try my purposed solution before you took it into the stealer and had then replace the whole unit? lol
I tried getting into the menu by pressing the buttons you mentioned but I can't get into it... Maybe I'm really a electronic idiot...
Oh ya!!!! I'm still alive... luckily... being tortured by work recently and very busy...
Still nothing from them...
I have to give them a call!!!! YA!!! I'll do it right now!
WOW!!! I just called and they told me that the parts is coming straight from Japan instead of somewhere locally!!!!!
They told me to call in 1 week if there's still no news from them...
In the meantime, have you kept trying to tune your voice rec. and see if it has fixed itself or something?
Otherwise, how are you enjoying your car?
