Vibrations?
Old May 7, 2008 | 12:40 PM
broeks's Avatar
4th Gear
Vibrations?
I'm wondering if anyone else has experienced this...
I seem to be getting vibrations in the driver side and passenger side doors. Sometimes it seems like its coming from the center console/arm rest area as well. Typically happens when downshifting (higher rpms) or with any sort of bassy music.
If I take this to the dealer on the warranty, would they do anything?
Old May 7, 2008 | 01:07 PM
broeks's Avatar
4th Gear
Sorry, I should specify that they are audible vibrations, like a buzzing sound. 06 tsx 25k miles
Old May 7, 2008 | 02:34 PM
davidspalding's Avatar
Make a hole, coming thru!
Searched for other threads? There was a TSB about door lining/soundproofing due to buzzing IIRC, too.
Old May 7, 2008 | 03:08 PM
broeks's Avatar
4th Gear
There aren't any other posts that I can find.
I did see the service bulletin prior to posting, but I don't understand if that is something the dealer will do for me? Or is that something I'd have to pay to get done?
I've never owned a car with a warranty before so i don't know what to expect.
Old May 7, 2008 | 04:46 PM
Jim Holloman's Avatar
Different dealers can give you different answers. And, you are not privy to any communications between Honda and the dealer regarding any such issue.
So, the only logical thing to do is to request that the problem be investigated, and repaired, under the terms of the warranty. You might have the burden to prove that the problem does exist and is recurring. In other words, can you cause it to occur on a test drive? I would put the request in writing. But, don't take it personally if the dealer declines the request. A lot depends upon the criteria established by Honda since Honda pays for warranty repairs.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
