tsx service schedule
Normal:
30,000 mi/48,000 km Scheduled Maintenance
Recommended service for your 2004 Acura TSX:
Replace engine oil.
Rotate tires (follow pattern on page 276 of your owner's manual).
Inspect drive belt.
Replace air cleaner element.
Replace dust and pollen filter.
Check engine oil and coolant at each fuel stop.
Check and adjust valve clearance, cold engine, only if noisy.
Severe:
Replace engine oil.
Replace engine oil filter.
Inspect front and rear brakes.
Lubricate all hinges, locks and latches.
Inspect tie-rod ends, steering gearbox and boots.
Inspect suspension components.
Inspect drive shaft boots.
Inspect drive belt.
Replace dust and pollen filter. (See Dust and Pollen Filter on page 270 of your owner's manual for replacement information under special driving conditions.)
Copied from Ownerlink for an '04. Should be the same for '05.
Replace engine oil.
Inspect drive belt.
Severe:
Replace engine oil.
Inspect drive belt.
Check out the FAQ
https://acurazine.com/forums/showthread.php?t=24744
IBankMouse
Jun 13, 2020 12:53 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
