Is the TSX the only Acura vehicle with "Fly by Wire" throttle?
Hey guys:
Is the Tsx the only Acura vehicle with Fly by Wire where the gas pedal is linked only electronically (and not with a physical cable) to the fuel throttle? Do the RSX, TL, or RL have the same system?
ive been wondering about it. is it really all wired? when the car is off n i have the drivers door open in my garage n i put my foot to the floor i can hear the throttle open up. like when u hear the thing open u hear a tap so it doesnt open ne more.... is that the pedal that i am hearing?
Apex Clipper
Originally Posted by YBA
My NSX does have electronic throttle (or drive by wire)...
Originally Posted by Carlos8542222
Hey guys:
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
Basically since the control surfaces on the commercial jets are so large. Along with the fighter jet's surface, since they need to pull sharp maneuvers, human muscle alone would never be able to pull it off going at high speeds. So there's actually hydraulics that move the control surfaces.
Originally Posted by goddsmack
either way, I still prefer mechanical linkage in throttle control, every car these days is drive by wire, even freakin trucks!
Just like the Toyota Tundra. It's a 275hp truck that can't do burnouts. I mean, a pickup with no weight in the back and a V8?
Well... it's because of the drive by wire system. They put that in there so that it could be the first ever ultra low emmissions V8.
It's a little annoying to some folks. But if you drive it normally, you actually can't tell the difference. Only when you are trying to race you can tell.
But it's still a nice truck nonetheless.
Originally Posted by Alin10123
It supposidely helps with emmisions. This way nobody can just gun it. When you gun it, it allows a ton of dirty exhaust to come out. If it's drive by wire, the electronic throttle can engage a little slower. That way the emissions will be cleaner.
Don't know who told you that but you've actually got it backwards. A very slight delay in closing the throttle plate can reduce emissions, as cutting off intake air all at once causes the mixture to go slightly rich. The primary reason though for DBW throttles is for VSA control, as the ECU will reduce throttle opening slightly in understeer conditions.
Delaying throttle opening on accel would do nothing to reduce hydrocarbon emissions.
Originally Posted by Tsx536
Does having VSA on take away any power?
Moderator Alumnus
Rep'n Taxbrain.com
Originally Posted by sauceman
Only on 2004 models: https://acurazine.com/forums/showthread.php?t=22171 post #4
Do you guys think that disabling VTEC effects the throttle response at all?
Got Milk???
Hey guys:
Fly by Wire? Too much grass perhaps, causing hallucination?
TL and RL both have drive by wire, RSX does not
The reason I asked was because with Hondata, Injen intake, and headers, I have noticed more hesitation at VTEC with VSA on. If I turn off VSA, I can definitely notice less hesitation/dip at the Vtec engagement point. Triz who has the same setup as me, has also noticed the same thing. In theory, it doen't make sense to me, so I'm trying to figure out what the cause might be.
Wonder if it's not a bug in the Hondata reflash?
Rep'n Taxbrain.com
Originally Posted by poltergeist
The VSA being "on" should not have any effect on throttle response (unless the car is actually starting to slide) or iVtec/VTC operation. I've never experienced what you describe with my car (stock) whether the VSA is enabled or disabled.
And it might also only be with the Injen intake. I'm still trying to figure that out.
It all doesn't make any sense to me, but I know I can feel the difference. I thought it was just me at first, but someone else also experienced the same thing.
Rep'n Taxbrain.com
^^ Sorry if my post was unclear. When I said that is might only be with Injen. I ment that is was only with a 5AT with Hondata and Injen intake, not just the Injen intake alone.
When I only had the Injen intake, I didn't feel any hesitation at Vtec.
I do also have a '02 Tundra and although the throttle is a cable (last year they made a cable linkage), the movement of the butterfly valve in the throttle body is still electronically controlled by the cable movement and an actuator. Older cars, you could rotate the valve on the side reel and the plate inside would move dependant of it. I don't know, I prefer hard linkage to electronically controlled items, if things go bad, your stuck with limited range and a more expensive repair as far as parts. The worst vehicle....the new Toyota Prius, everything from braking, to steering, to the tranny is electronically controlled.
elietania
4G TL Problems & Fixes
09-05-2015 06:52 AM
