TSX clutch Or tranny issues???
Hey guys, New member as i just purchased my first acura..
So i bought my 2005 6Mt Tsx last week. I noticed that it would sometimes grind when it went into reverse and into first. Did some research on here and swapped out the slave and adjusted the clutch travel slightly. This has made a world of difference when it comes to the clutch going into gear.
However once i hit the freeway and opened it right up it almost feels that certain gears are blocked. If i try to shift quickly its like i hit a wall(won't go into the gear i'm shifting into) so i have to sit in N for a few moments before it wil actually slide into 3rd or 4th or whatever.
Is this a clutch issue? I thought my problems were solved with the slave and clutch adjustment. Wondering if it only made a small difference and i'm going to need to shell out for a clutch?
Any thoughts or experience with a case like this.
cycdaniel
12-17-2019 10:58 AM
kixo
09-05-2015 08:54 PM
