TSX Brakes
3rd Gear
TSX Brakes
I just test drove speed TSX at the Keys acura in van nuys and what suprised me was that he brakes were not as firm as i had expected. i have driven a mazda6 and it had a much firmer brake pedal. was it this particular car that had soft brake pedal or are all TSX's have soft-ish brake pedal feel. ley me know...thanx
I don't have this problem with my car. Funny, I feel my brakes are kind of sticky though. I mean they feel more on/off and less brake feel.
Is this just me??? Maybe I need my car looked at...
I feel the need...
I agree with the brake issue - had the same experience when I tested the Mazda6 before the TSX. The brakes have much better 'feel' on the 6, however that didn't prevent me from still choosing the TSX after considering a host of factors.
nothing but acura
Honda and Acura use a specific brake pad matterial that reduces the amount of brake dust that collects on the wheels to a very large degree. Using this material both decreases the strength and feel of the brakes. They should make some sort of option for whether or not you want really strong brakes with lots of dust, or the ones they put on right now, but it has been this way with honda products for the last 10 years.
Considering that brake pads need to be replaced regularly, you can just bring your mechanic the brake pads you want installed if this concerns you.
I found the brakes to be as linear and easily modulated as every other Honda product I've ever driven and I like it better than the Mazda 6 (of course, this could also be due to my tendency to brake harder earlier in the braking and slowly reduce pressure as I lose speed).
I kAnt Spel guD
I think the TSX has some of the best brakes I've ever felt, now my car was purchased cert. used with 6400mi on the clock, but d@mn our car brakes like NOW! I love the TSX brakes much-much better then the Mazda6 5-door we drove.
How many miles did your tester have on it?
The Mazda 6 brakes/rotors have serious defects/problems. There is a huge issue currently going on where many are prematurely warping due to unknown problems.
Got Milk???
i wouldnt say tsx brakes are great, but they're decent. just drove for a trip to the mountains with my parent's BMW X5 , now those brakes are SWEEEEEEEEEET.... only wish i can fit those brakes onto my tsx
oh by the way, yes my brakes are kinda soft, been doing that since i picked it up at acura of pasadena
Not an Ashtray
I kAnt Spel guD
Originally Posted by Bizzenn
Every 4000 miles the rotors warp on my TSX. Has anyone had this problem?
Are you having the rotors tunered to remove the warping?
This is only going to accelerate the warping.
Most car mfg. actually cast their own rotors in house, even Honda, as such you may just have gotten a bad casting for your rotors.
A sure fire fix for this should be a new set of rotors--a quality set of aftermarket rotors may even be better then stock in your case. While you're at it you may even want to swap in a nice set of new pads. Satified Pro and Hawk both make some affordable pads that I really like.
They have been turned. And exactly 4000 miles later it warps again. Mabe this time they will replace them. And correct me if im wrong but doesn't the brakes have a 12 month warranty from acura?
Registered AssHat
I went 14K miles on mine (before I sold it) with no vibration in the brakes. And that's with hard 100 mph to 5 mph stops on a weekly basis.
Originally Posted by Lung Fu Mo Shi
Are you glazing (break-in) them properly? Doing lots of hard braking to a standstill? If so, the rotors aren't warping, but you're leaving brake pad deposits on the discs causing vibration through the pedal.
undefinedWarped rotors on a new car......already!!!!!!!!!!!!!!!!!!!!!! I have plans to sell my 02 RSX-S and purchase a TSX but all of these issues are driving me crazy. Are we sure we are all talking Acura here?????? i.e Honda.......i.e. reliability.......i.e. trouble free!!!!!..I haven't had any problems with my RSX other than one small rattle.....maybe the grass isn't always greener on the other side.
I kAnt Spel guD
I think this is the exception not the rule, mine are fine.
Getting a tsx is safe. Its been an excellent car. This is the only problem I have had with the exception of a bad door stop. I will say this though, I have had 3 hyundais that have been my best cars and most trouble free cars owned.
The TSX is a typical Honda product... very nice & reliable...
The brake problem discussed here is only an annoyance [pulsing/spongy pedal] and the brakes work perfectly... [mine does it too]
But there is a great deal of customization possible with Honda/Acura products because there are so many manufacturers [Japan & USA & Europe & even Australia] building hi-performance/racing parts so it's very easy to upgrade any part of the car whether you're satisfied or not...
I'm looking at upgrading my brakes right now... probably will try Axxix Ultimate or Hawk HPS pads and if not satisfied with that, I will go with a Brembo 13" brake upgrade kit... I will also upgrade the suspension with lowering springs/shocks or coil-overs... not sure which yet...
Good luck...
Good luck...
I have 25,000km on my TSX and no warped rotors.
By the way, there is lots of info on this problem if you want to try a search.
Git er Done!!
I was very dissappointed with the brakes on the TSX. My brakes went to garbage in 14k miles. My Integra brakes held up longer then that and I drove that car a lot harder.
Acura wouldn't do anything for me under warranty without a fight. They did throw on a set of new front rotors, but that did not fix the problem. So I ordered a full set of EBC GreenStuff pads for all four corners from TireRack. And after I broke them in and bedded the pads in, the car stops amazingly now. The brake pedal feel improved and the application of the brakes is much more linear. For the price, it's cheap safety in my book. About 60 bucks for the front and about 40 for the rear. Oh, also the VSA works much better now to help the car rotate around corners, because the back brakes can actually help out better because of the high coefficent of friction at 0.46 compared to the stock pads of around 0.32. These pads will also hold that friction to 1000 degrees F.
During the initial break in process the pads were very noisey. They squealed all the time during braking. These pads came with a break in material that was on the pad. After about 200-300 miles I bedded them in. For those who don't know what that is, it's when you do 5-6 60-5mph stops without engaging the ABS. That gets the pads so hot that the pad material embeds on the surface of the rotor. After that the squealing went away and the stopping power was great. I actually had to bed them in twice because the first time I didn't do it hard enough. So five or six 80-5mph stops did the trick . During that process when I came to stop smoke was pooring out of my front wheels over the front of the car . It was like I had the e-brake up and was doing a burnout. But that fixed it and they work great now.
I second the opinion the EBC green pads solves the problem.
They have strong initial bite that gives you confidence, good modulation,
and don't fade. I'm really pleased with
the improvement. I did have some noise when the pads were new
in really cold weather, like 15-20 degrees, but not yet this winter.
I wonder how the Hawk compares if anyone has run hawk and ebc back
to back ?
At about 22k miles, they are worn 50%, OE pads are ceramic and last longer
so watch your pad wear with EBC. Not at issue for me, 45K out of pads
is fine if they work. There's a pretty big wear ridge showing on the inside of my
rotors but not the outside. I figure next brake change next year, I will
do the slotted iRotors ( not drilled ).
On the rotor runout, I haven't had any problem. It may be that I torque
my wheels and don't let any shop put an air gun on them.
I Torgue them up at 10ft-lb steps to 75 ft-lb. I've had the problem
on other cars that was fixed fine by resurfacing.
to back ?
Well I've had my AXXIS Ultimate brake pads on for a few days now and they are great... nice consistent bite cold or hot... no fade... no more spongy pedal...
I did not have the rotors resurfaced... I figured these pads are abrasive enough that they'll take off any coating left by the OE pads...
Of course I had to "cook" them [bedding procedure] which didn't take much time...
I just did 5 medium pressure stops from 60 to 10mph followed by 5 hard stops from 60 to 10mph... then let rest for 2 hours or overnight if possible...
The next morning they were exhibiting the behaviour described above...
Wish I had done it earlier...
The Ultimates are a blend of kevlar, ceramic & metal...
Moderator Alumnus
Glad to hear you two guys got good results out of breaking them in right.
I'm more and more tempted to believe that the state of your rotors are revealing as to what kind of driver one is.
SidhuSaaB
05-30-2020 12:40 AM
Eggs999bacon
09-24-2015 10:08 AM
