Trans fluid change
Old 05-26-2018, 07:00 AM
Tommyboy75's Avatar
Trans fluid change
Hey everyone. I've owned two TSXs in my life, but I've never changed the trans fluid. My question is, can I use Castrol transmax import or do I have to use Honda fluid Thanks in advance
Old 05-27-2018, 01:04 AM
01acls's Avatar
Yes, you can use any ATF that meets GM Dexron VI.
Old 05-27-2018, 07:44 AM
mrgold35
mrgold35's Avatar
Received 1,519 Likes on 1,185 Posts
My dealership does a 1X drain/refill for around $100 or 3X drain/drive/refill for $300. Honda/Acura transmission don't like any type of "flush" or anything that replaces 100% of the AT fluid if you decide on chain or local shop.
Old 05-27-2018, 12:18 PM
01acls's Avatar
100% ATF exchanges (drain and fill) are best for any trans because it remove almost all of the contaminants from the trans and replenishes the trans with vital new ATF. There is no down side to a 100% ATF exchange.
kixo
08-15-2015 08:32 PM
Adamo0926
09-06-2014 08:12 PM
RC99TL
02-23-2010 10:40 AM
conester
04-10-2008 01:09 PM
CLSinTO
11-09-2001 01:38 AM
Quick Reply: Trans fluid change
