Torque Wrench
Old May 20, 2004 | 11:15 AM
leftride's Avatar
i want to ride my bicycle
Torque Wrench
Hey guys I am looking at picking up a torque wrench, mainly for my wheel lug nuts and anything else that may require one. I was look at this:
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
I was wondering if the price and specs looked ok? I was going with Craftsman because I have been using them for a while with no problems.
I assume if I do more work I will also want a 3/8" drive.
Old May 20, 2004 | 11:23 AM
Dan Martin's Avatar
Photography Nerd
That's the same one I have. It does everything I need it to do and is good quality. Just a tip: with any spring loaded torque wrench be sure to adjust the torque down to 0lbs when you are storing it. It will help maintain the spring.
Old May 20, 2004 | 11:27 AM
xizor's Avatar
Bye TSX, hello domestic?
I bought this one yesterday link.
It looks too cheap to be good, but my roommate has the exact one (bought for $30) and it works great.
That site was some really good prices. I ended up buy $60 of stuff, free shipping and $5 off coupon available online. Got a creeper, breaker bar, torque wrench, socket adaptor set, some racheting wrenchs and a cheap multimeter.
Old May 20, 2004 | 11:46 AM
leftride's Avatar
What about beam torque wrenches?
Old May 20, 2004 | 11:53 AM
leftride's Avatar
Dan do you just use an adpater for smaller sockets or do you have a 3/8" as well?
Old May 20, 2004 | 12:44 PM
Dan Martin's Avatar
Photography Nerd
I have a set of 1/2" and 3/8" sockets but both kits came with adaptors to convert from one size to the other. I have always liked craftsman stuff especially their lifetime warranty. If you ever brake something just bring it to Sears and they'll hand you a new one. They don't even ask for a receipt.
Old May 20, 2004 | 01:07 PM
cmf's Avatar
cmf
ATCer
virus7...what's the difference in your torque wrench vs the one they show for 139 for tires...or so they say on the Sears site...first link?????
Old May 20, 2004 | 02:09 PM
leftride's Avatar
cmf, I am not really sure why its 2x as expensive, it does have a rating to 250 ftlb as apposed to 150. It also looks a little beefier. and a "protective rubber cover"
"Micrometer-type setting adjusts quickly and easily from 30 to 250 ft. lb. in 1 ft. lb. gradations (47.45 to 345.68 Newton/meters) with only 8 deg. hand travel. Round head design has a protective rubber cover."
Old May 20, 2004 | 06:25 PM
Krazy_j604's Avatar
i have been using snap-on torque wrenches for awhile and i swore by them... its just the feel of it, i got the torsion click type and remember they must be recalibrated every now and then
Old May 20, 2004 | 08:24 PM
TSX007's Avatar
I have the same one...good product and of course it's a craftsman.
Old May 20, 2004 | 11:00 PM
JTso's Avatar
I have the same torque wrench as well, but their lifetime warranty does not apply to torque wrenches.
Old May 21, 2004 | 05:13 AM
nyc1badmofo's Avatar
Acura Technician
If you want reliability, beam torque wrenches are the best. Cause if you use the regular torque wrenches like the clicking ones, problem is that they need to be calibrated once in a while and if you drop it. forget about it.
Old May 21, 2004 | 10:19 AM
JTso's Avatar
I have used both beam and click torque wrenches and found the beam is less accurate especially after using it on heavy torque settings. The beam doesn't stay center after awhile. The major disadvantage of the beam is, if you can't read the scale in tight spaces, then it's useless. The clicker is not perfect either. It does need recalibration after heavy usage and I would stay away from really cheap clickers. It's too cheap to take it in for recalibration (not worth it) and not reliable enough for major work such as engine building, or even the oil drain plug.
Old May 21, 2004 | 11:14 AM
leftride's Avatar
will sears recalibrate them?
Old May 21, 2004 | 06:14 PM
Acura Technician
oh just go buy snap on. I got both snap on clickers and beams. I depend on beams more when I go for lug nuts. clickers are more for engine work.
Old May 22, 2004 | 01:49 AM
KingV's Avatar
I have both a beam and clicker type. I much prefer the clicker. The beam is just seems too inaccurate for me. I have difficulty looking at it and torquing to spec at the same time. Also, the increased rigidity of the click type actually makes it so you require less force from your arm to actually make the needed torque, since you don't have to bend the shit to make it work. I figure there's no way at home that I'll use a clicker type enough to really worry about wearing it out.
Old Apr 24, 2005 | 11:01 PM
dP-'s Avatar
dP-
Bringing this back up as I'm getting a wrench.
OK, for the lug nuts will a 3/8 do the job, or do you have to have the 1/2. I know that the 3/8 has enough torque to do the job, however I have already tried doing one with the 3/8 and my 19mm socket (not deep) thus used the extension on it. Needless to say, the extension lost in the battle and I broke it. No worry since it was Craftsman. I was thinking about buying a 19mm deep socket with the hope it will help.
Anyone with a 3/8 torque wrench who torques the lug nuts on here? Or is eveyrone using the 1/2?
Old Apr 25, 2005 | 05:35 AM
Master47's Avatar
Out of curiosity, what is the torque spec. for the TSX lug nuts?
Old Apr 25, 2005 | 09:36 AM
TSX 3Pedal's Avatar
Use all 3 Pedals at once
I think it's 80 ft-lbs.
Someone correct me if I'm wrong
Old Apr 25, 2005 | 09:37 AM
Dan Martin's Avatar
Photography Nerd
80lbf-ft
Old Apr 26, 2005 | 01:30 AM
Arcticcl9's Avatar
Can't wait to drive
Call me cheap, but I got this one..click-style and works like a charm I'm actually amazed by its quality, I've been using it on my car for over a year.
http://www.dropshippedproducts.com/s...uct.asp?ID=197
knight rider
Mar 4, 2016 08:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
Skirmich
Oct 1, 2015 12:59 PM
hpfiend
Sep 27, 2015 06:59 AM
Rcelestino93
Sep 23, 2015 10:01 PM
