Topped out the TSX speed.
well. my family doctor moved out of the city to okotoks, which is like a 20 minute drive out of city limits. i had to go for a referal to gget my tonsels out.
there is a beautiful highway, 3 lanes, low traffic. i drove there going full speed.
tsx topped out in 5th at about 200ish, 6000 revs, would not go higher,
shifted to 6th, it climbed up to 213 km/h and could go no faster, even on downhills. so that is the topspeed in 6th. feels damn good , i forgot to note revs tho.
i may have gotten a multi nova coming home on the shitty side of the higway.
parked blue van, my radar detector didnt notice anything, i sloowed down to 20km/h over limit still and then my detecter beeped once i passed the car. im praying to not get anything in the mail.
maybe i should go back and blow up the van
I've hit 200 in my TSX and it had plenty left on tap. 213 sounds low to me, unless it is governed by the computer. But I'm almost positive there are members here who have gone past 213.
Sorry to kill the mood, but isn't it a tad irresponsible to go that fast on a highway, no matter how low the traffic is? At that speed, you're pretty much guaranteed to kill somebody (as well as yourself) if you hit their car.
Moderator Alumnus
Originally Posted by jeffb
Car & Driver tested the TSX in June 2003 and got a drag-limited (as opposed to governed) top speed of 133 MPH
I did it twice, the first time was for the sake of seeing how fast it would go, and at 143, it was still gaining speed. Domn is probably right about the 150mph mark.
The second time was in a dramatic situation when I had to drive a 20 minute rush (usually would take 45min) to the hospital when I had to drive one of my best (girl) friend's brother to see her one last time because she was dying of a level 4 brain tumor, and had only a few minutes or hours of consciousness left for her. Turns out he got to tell her only a few words before she fell into a definite coma. Sad, sad story.
Anyhow... getting off topic here, let's not get into these painful souvenirs.
But I do know the TSX is good for at the very least 135kph.
I am Ahab!
Originally Posted by TSX Cman
the tsx COULD go faster. damn cimputers
it limits 5th gear to not enter vtec range.
it limits 6th gear really high, at 213hm/h
Moderator Alumnus
Just want to remind folks that the speedometer readout in the 130-140mph area is most likely not accurate, but a bit high. Not sure what the correction is, but my guess is C&D measured it externally (not speedo).
I was about to say. My Odo on my GS-R read just over 240 but I seriously doubt that was accurate. But I'm convinced the TSX could hit 140MPH, although I'll probly never find out first hand.
Go Dutch !
On the German autobahn my euroAccord climbs up to 225km/h (140mph) easlily. Going slightly downhill I've hit the rev limmiter several times at 248km/h (155mph). I have a manual tranny though, don't know about the AT (it should lower)...
Idea: next time someone tries a top speed run...
Pop the navi (if you have it) in diagnostic mode and see what the GPS says the speed is instead of using the speedometer. I've checked it at normal speeds and it's pretty accurate, but I've only peaked at 100.
i got it up to 230 kph a few months ago. Didnt go any faster because cross wind was becoming a problem I'd say the car could peg the speedo, and thats it. Real speed was prob a tick over 200 i figure. The TSX can effortlessly hit 200 though, still in 5th. If there was no speed limit, I think 200 would be a nice cruising speed. That being said, I usually never go more than 10 over the limit, toooo many cops in calgary, and i think theres probably more photo radars than cars on the road.
Captain-Oats
i-VTEC
i-VTEC does not have a "range" - instead the "i" for "intelligent" computer allows VTEC to be operational across the entire rev range.
Hence of course 5th gear IS in fact operational in the (i)VTEC range - which is the entire rev range.
Originally Posted by captain-oats
The TSX (Honda Accord Euro) employs i-VTEC instead of traditional VTEC technology.
you're right that ivtec allows control over the entire rev range, but there is still a vtec point at which the cam swicthes to a more aggressive lobe, and on the TSX this is at 6000 rpm. So really one could say that 6000+ is vtec range on the TSX.
Originally Posted by tony4311
no, no it's not.
no its not doesnt even go along with the present/past tense choice of my statement
and im not bullshitting. i checked my top speed for the reason of checkin it. maybe canadian tsx's have a different govern level then the US model, or euro model, or jap model.
MY TSX goes the speed i stated, it tops out when i said it, and on a downhill i could not go any faster than i did unless i dropped it into neutral probably.
and i dont know waht to say about the 5th gear thing. i had my foot down to the floor. it hit 6000 trevs and refused to go any faster. the second i went to 6th, the speed picked back up quite quickly.
Captain-Oats
The ECU is monitoring LOTS of variables, not just the rpms. And therein lies the beauty of i-VTEC.
Moderator Alumnus
what does this mean?
Maybe something was wrong, you were running with 87 or something, and your ECU was going on limp mode or whatnot.
The Honda New Zealand website agrees that there is more involved in the transition of the cam than just the rpms: As engine rpm builds, a VTC actuator - controlled by an engine-control unit that monitors cam position, ignition timing, exhaust emission and throttle position - advances or retards the intake cam.
I'm not disagreeing with you. All that stuff does happen below 6000 rpms, and that IS the beauty of i-vtec. But at 6000rpms, a completely new cam comes into play and this is what is commonly reffered to as "vtec point" or "vtec range".
I would trust C&D numbers (at least for US versions). The speedometer is most all production cars is rather inaccurate above 100mph -- so quoting a speed from it is rather meaningless.
Originally Posted by observer
That's interesting; I never thought of it. So when you're ticketed for super high speed can you just say that you don't know how fast you're going because the speedometer is inaccurate?
